Old 06-23-2015, 14:31   #1 (permalink)
.::EXTREME::.'s Avatar
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
Where the backup file located in Cm2mtk?
Just formatted. Dont have full flash read file.
But when on format, software backup done.
Can i use that file to retrieve fone? where it located, or how to flash that file to phone?
now the phone shows only XOLO and Tool DL image fail.
Start  at : [6/23/2015 / 6:35:53 PM]
Operation : Format FileSystem [ v1.21 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 110100303034473930515C8742EE71A5
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0011 , OEM : 0100
[eMMC] : FLASH_INF : 09G40
[eMMC] : FLASH_CID : 110100303034473930515C8742EE71A5
[eMMC] : FLASH_LEN : 0x00000000EC000000
INT RAM    : 0x00020000
EXT RAM    : 0x20000000
BOOT TYPE  : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Backup : not found, will read now ...
Format : Cache Only
Format CACHE block
Format block Ok!
Done!
Elapsed: 00:00:37
Reconnect Power/Cable!
Finish at : [6/23/2015 / 6:36:31 PM]
Start  at : [6/23/2015 / 6:36:52 PM]
Wait for phone...
Phone found! [ 15 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Backup : Already exist
FMT Mode set to : 3
Format : Cache and UserData (Full Factory Reset)
Format CACHE block
Format block Ok!
Format UDA block
Format block Ok!
Done!
Elapsed: 00:00:34
Finish at : [6/23/2015 / 6:37:26 PM]
Start  at : [6/23/2015 / 6:37:58 PM]
Operation : Fix DL Errors [ v1.21 ]
Wait for phone...
Phone found! [ 15 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
DA start Failed!
Check battery , cable , drivers and try try again
Boot Error!
Operation Failed
Elapsed: 00:00:10
Finish at : [6/23/2015 / 6:38:09 PM]
Old 06-23-2015, 14:39   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
It seems really hard to press "Fix DL" button, right?
The Following User Says Thank You to JayDi For This Useful Post:
Old 06-23-2015, 14:48   #3 (permalink)
Member: 1619462
Sonork: 100.1606509
Thanks Meter: 1,517
Card found: 1111111121121
Chinese Miracle II [MTK module] v 1.21
Wait for phone...
Phone found! [ 15 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:16
Thank you.
Its Done!
Beginner With your tool
Old 06-23-2015, 15:52   #4 (permalink)
JayDi's Avatar
Member: 462970
Will add that automatically to "Format FS" , "Reset Privacy" operations in next version to avoid such things.
The Following 4 Users Say Thank You to JayDi For This Useful Post:
Page generated in 0.16082 seconds with 9 queries
