11-02-2015, 14:57 | #1 (permalink) |
No Life Poster Join Date: May 2003 Location: Jamaica
Member: 28559 Status: Offline Thanks Meter: 85 | how to connect to spd phones? Start at : [11/1/2015 / 2:51:11 PM] Operation : Format File System [ v1.05 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Device boot not done Check Drivers Try again Reconnect Power/Cable! Finish at : [11/1/2015 / 2:51:56 PM] Start at : [11/1/2015 / 2:52:18 PM] Operation : Format File System [ v1.05 ] Start at : [11/1/2015 / 2:52:20 PM] Operation : Format File System [ v1.05 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... |
11-02-2015, 15:06 | #2 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Install SPD drivers from support site Use Boot key from phone,(tried different keys combination) for fast(magic) result... Use Boot Cable for more info about Boot cable, Read DOCs(x:\InfinityBox\CM2SPD\DOCs) |
11-03-2015, 06:47 | #3 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | if you don't have boot Cable better to pinfind with any box and just do with cm2 i,m always use this trick Long time no have any problem in SPD,MTK and RDA |
11-03-2015, 07:34 | #4 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: india
Member: 1161713 Status: Offline Sonork: 100.1607798 Thanks Meter: 421 | Quote:
1) how to use other box with cm2 MTK OR SPD pl z make some video for better help how to connect with cm2 to box and how to pin find with box | |
11-03-2015, 08:05 | #5 (permalink) | |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | Quote:
while cm2 search port for any job....., do scan pinout with any box pin finder. And need NOT to apply pinout make sure pinout found before cm2 stopped searhing port br | |
03-12-2016, 09:40 | #6 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: INDIA BHUBANESWAR
Member: 641849 Status: Offline Sonork: 100.1619689 Thanks Meter: 44 | Quote:
SAME PROBLEM ITS NOT CONNECTING WITH USB I TRIED WITH OTHER BOX IT CONNECTS and have installed all spd drivers correctly | |
