05-08-2015, 10:30 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: Infinity Club Age: 43
Member: 306118 Status: Offline Thanks Meter: 192 | How to Fix this ERROR: Probably - "Secure Boot" or "BootLoader Locked" phone pls help me how to fix this error on any operation on Huawei G610-U20 & several other models ***** by SP AUTO on SETTING Operation : Check / Read Info [ v1.19 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending Error : DA init Failed! Error code : 0x3 Probably - "Secure Boot" or "BootLoader Locked" phone Boot Error! Operation Failed Elapsed: 00:00:20 Reconnect Power/Cable! --------------------------------------------------------------- **** by SP SELECT MODEL (Huawei Secured G610-Y330) Operation : Check / Read Info [ v1.19 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6583 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6583|6589_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage Will use Secure DA for boot target DA Select done , sending DA Stat : v3.2 on BBID : 0x86 DA Sent. Configure setting now ... DA start Failed! Check battery , cable , drivers and try try again how to fix this errors??? Last edited by farshid-jan; 05-08-2015 at 10:37. |
05-08-2015, 10:48 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Unlock bootloader ( if it non - secured ) or wait, when I find such sample. |
05-08-2015, 18:20 | #4 (permalink) |
No Life Poster Join Date: Jan 2008 Location: PAKISTAN KARACHI Age: 44
Member: 686395 Status: Offline Sonork: 100.1608345 Thanks Meter: 3,822 | you can't read factory firmware w/o unlock bootloader |
The Following 2 Users Say Thank You to maanarman For This Useful Post: |
