03-18-2009, 06:05 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: MX-Key and me ...The Best
Member: 617692 Status: Offline Thanks Meter: 306 | How to flash Chines Nokia I want to flash chines nokia just like 1100, 1110, 5310 etc but I do not know about the flashing. I searched the support area but do not found chines nokia files. what kind of cable shold be used for chines nokia? (I have also RJ 45 cables of UFS Where would I download chines Nokia files? Should I flash chines nokia with ufs3 with orignal files (Mcu,cnt,ppm)? thanks in advance... (Infinity the best) I have infinity box + pinfinder |
03-18-2009, 10:38 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Hello, Flash files for "Chinese" models: \flashfiles\ChineseMiracle Documentation: C:\Program Files\InfinityBox\Documentation\ChineseMiracle How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
03-22-2009, 05:16 | #3 (permalink) |
Member: 617692 Status: Offline Thanks Meter: 306 | thanks...thanks...thanks....and again thanks.... best infinity box...best support I Know all the aboue info....but the problem is that (for example) there is a chines nokia 1110i and I want to flash. My ufs detects it but says unkown flash chip so this is pure china. In UFS3 we flash orignal Nokia 1110i with three files MCU+PPM+CNT and use RJ45 cable. So I want to flash with infinity the chines nokia 1110i. I ask that will it be flash with the aboue three files or just like chines miracle? what kind of cable will be used? Can I use orignal RJ45 ufs3 cable with infinity box or infinity pinfinder? |
03-22-2009, 06:55 | #4 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | this not china phone means this is NOKIA cloned CPU based phone open the phone and see inside that what is the main CPU if this CPU is MTK or other china phone CPU. than you can format it by infinity using the valid pinouts WBR G S M - D O C T O R |
How to flash dead nokia phones with jaf usb flashing | tiju kkm | Nokia Hardware & Hardware Repair | 0 | 01-24-2009 20:58 |
how to flash chines set | neeraj_chandi | Infinity-Box | 1 | 01-07-2008 15:26 |
how to flash chines handsets | neeraj_chandi | Infinity-Box | 1 | 01-07-2008 15:26 |
how to flash chines mobile !!! | M@TRIX | Various | 4 | 11-09-2007 19:11 |
how to flash new NOKIA 6300 with HWK what cable to use | tsarkh | HWK | 12 | 05-03-2007 11:29 |
