07-18-2016, 20:38 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: pakistan
Member: 270869 Status: Offline Sonork: 100.1600061 Thanks Meter: 429 | how to flash G610-U20 Chinese Miracle II [MTK module] v 1.51 Operation : FastBoot : ReadInfo [ v1.51 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 27 ] Sync... Device verify not done Install drivers , repeat operation Switch to normal boot now ... Operation Failed Elapsed: 00:00:50 Reconnect Power/Cable! Operation : FastBoot : Unlock BootLoader [ v1.51 ] Power Off Phone , re-connect battery , Insert USB cable! Wait for phone... Phone found! [ 27 ] Sync... Device verify not done Install drivers , repeat operation Switch to normal boot now ... Operation Failed Elapsed: 00:00:44 Reconnect Power/Cable! Operation : Check / Read Info [ v1.51 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6589 , Project : MTK6589 , Storage : eMMC Files found : 10 , Set to Flash : 9 Ready to Flash! Operation : Flash [ v1.51 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:08 Reconnect Power/Cable! |
07-18-2016, 20:53 | #3 (permalink) | |
Freak Poster Join Date: Jul 2013 Location: CAIRO.EGYPT
Member: 1981679 Status: Offline Thanks Meter: 86 | Quote:
Flash secro file first then full flash. أرسلت من HTC Desire 816 dual sim بإستخدام تاباتلك | |
