09-27-2009, 09:35 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: Sambrial (Sialkot)
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | Sigmatel s98 "Not Clibrated" solved 100% COM8 [VCP0] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active skip: Firmware skip: Customization/Language Pack skip: Customization write: Eeprom/ffs T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88.B0E.bin ffs/eeprom backup enabled, it may takes several minutes ! Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:1C03:0002 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [standard] generation rom info detection finished rom info protocol ver: 04 ver. sw 1: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL.BIN ver. sw 2: T600_V04_EnFrArRuSpPeVi_SIGMATEL, 00000000 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detect device sec info... detection phase #1... . detect device sec info finished Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... reading: T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__ffs... file saved: E:\InfinityBox\ChineseMiracle\T600_V04_PCB01_GPRS_ MT6225_S00.T600_V04_ENFRARRUSPPEVI_SIGMATEL__ffs_2 0090928-022338.B0E.bin flash: 2088C4FFFFFFFF:2088C400000000 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... Area: Eeprom/ffs flash: 2088C4FFFFFFFF:2088C400000000 Write: Eeprom/ffs detect device sec info... detection phase #1... . detect device sec info finished Write Done Finalization ... Finalization Done Finished, time used: 263 sec Remove/Install battery now ! |
The Following 6 Users Say Thank You to zeerik For This Useful Post: |
09-27-2009, 14:24 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! was it "tochscreen" not calibrated? did you try to solve it by "bypass touchscreen calibration" ? |
09-28-2009, 14:21 | #3 (permalink) |
Member: 282066 Status: Offline Sonork: 100.1590696 Thanks Meter: 569 | it is not tuch screen calibration problem ........first of all i tried clibration tuch screen option (all mode) ..............but not fixed........then problem solved flashing with eeprom file |
09-28-2009, 21:21 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i will add this file to support with a name T600_V04_PCB01_GPRS_MT6225_S00.T600_V04_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-s88_eeprom_for_not_calibrated.B0E.bin |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
09-29-2009, 14:44 | #5 (permalink) |
No Life Poster Join Date: Jul 2008 Location: Sharja UAE
Member: 820592 Status: Offline Sonork: 100.1590378 Thanks Meter: 327 | yes for me working 100000000000000% perfect sloution thank you very much MR. |
The Following User Says Thank You to Hafiz ArslanAli For This Useful Post: |
10-05-2009, 07:44 | #8 (permalink) |
Freak Poster Join Date: Sep 2006
Member: 360614 Status: Offline Thanks Meter: 63 | Any possible idea with spiderman, cause I don't have infinity. Or can u give me a link of flash file of sigmatel S98 MTK_ROMINFO_v04T600_V05_PCB01_GPRS_MT6226_S01.T600 _V05_ENFRARRUSPPEVI_SIGMATEL.BIN |
11-15-2010, 08:40 | #10 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1047695 Status: Offline Sonork: none Thanks Meter: 0 | i need a flash file sigmatel s98 plz send me thankx in advance [email protected] |
11-15-2010, 21:56 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
which is required software version? do you have infinity box? | |
03-08-2011, 09:49 | #12 (permalink) |
Freak Poster Join Date: May 2010
Member: 1304552 Status: Offline Thanks Meter: 20 | i need eprom for s98 the attached eprom is not working plz give eprom for the given firmware - T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-S98_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M |
03-12-2011, 21:07 | #13 (permalink) | |
what problem you have with your phone? did you try to make format FFS? this rebuild EEPROm to factory state | |
05-15-2011, 07:33 | #14 (permalink) |
Junior Member Join Date: Oct 2008 Location: punjab,india
Member: 878884 Status: Offline Thanks Meter: 3 | hey dear i also need this file of sigmatel s98 eeprom T600_V05_PCB01_GPRS_MT6226_S01.T600_V05_ENFRARRUSP PEVI_SIGMATEL__Sigmatel-S98_16m_En_Ru_Fr_Es_Vn_Farsi_Ar.B0M |
sigmatel s98 | shihabps | Chinese Models & Cloned Phones | 8 | 10-05-2009 09:48 |
sigmatel s98 "Not Calibrated" error | zeerik | Infinity-Box | 9 | 09-28-2009 21:15 |
I need Sigmatel S98 help me | Tamansu | Chinese Models & Cloned Phones | 4 | 08-12-2009 16:54 |
sigmatel s98 dead after code *#33646633# | dakku | Chinese Models & Cloned Phones | 0 | 03-07-2009 16:42 |
