Old 09-26-2009, 13:08   #1 (permalink)
Member: 720284
Thanks Meter: 13
how to flash lg on infiniti box
how to flash lg on infiniti box.because i do not know what is the function of read flash read ful flash and do not know eeprom ffs and more and do not know about the file please tel me step by step or plesssssssssssssssssssssssssssssssssssssss
Old 09-26-2009, 13:41   #2 (permalink)
sheik9905677786's Avatar
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
how to flash
Step1=select brand/model
Step2=select model
Step3=Run
after do this automatically open one window(pana)
step4= select device
step5=check com port
step6=Flash a.load firmware, b.load language pack
final step=click on write.
thanks!!!!!!
The Following 2 Users Say Thank You to sheik9905677786 For This Useful Post:
Old 09-26-2009, 14:15   #3 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
How to write flash (upgrade/downgrade firmware, change language):
1. connect cable from box to device
2. run "Infinity-Box Shell" software
3. select required model
4. run required software module
5. select required model (if need)
6. go to software "Settings" page and select COM port
7. go to software "Flash" page and load required files
8. press "Write" button and follow instruction given by software
How to read flash:
7. go to software "Service" page
8. press "Read flash" (or "Read full flash") button and follow instruction given by software
How to unlock (remove sp-lock, provider lock etc.):
8. press "SP-Unlock" button and follow instruction given by software
How to reset/format ffs (reset setting to default values, repair freez/restart etc.):
- at first try to make "safe format" (if this option exist)
- if "safe" option is not works try to make "complete" format (if this option exist)
8. select format mode "safe" or "complete" (if mode is available)
9. press "Reset" or "Format" button and follow instruction given by software
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 09-27-2009, 09:24   #4 (permalink)
Member: 720284
Thanks Meter: 13
But there are many function on flash page
BUT THERE ARE MANY FUNCTION ON FLASH PAGE FIRST LOADFIRMWARE SECOND LANGUAGE PACK THIRD FFS FOUR EEPROM and sport side have only bin file.please tell how to recognize the firmfare and language file
Old 09-27-2009, 09:57   #5 (permalink)
Member: 76018
Thanks Meter: 59
you can find the Files for your Modell in Support... when you see whcih Files you need to flash.
If you use a Box you should have a little knowledge about Computers/Mobiles
Old 09-27-2009, 10:35   #6 (permalink)
Member: 720284
Thanks Meter: 13
I know sport side but i do not know who is firmware language ffs and eeprom file please tel how to recognize these file pleassssssssssssssssssssssssssssssssssssssssssssss sss
Old 09-27-2009, 11:15   #7 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
model
oh my good ness i think u r new user. ok let me tell u.
firstly give me full question that about which model you desire to flash?
because there lots of model. and there is also lots of extension of file.
thanks!!
Old 09-27-2009, 15:45   #8 (permalink)
Member: 1064310
Sonork: 100.1680646
Thanks Meter: 26
thanksssssssssssssssssssssssssssssssssssssssssssss sssss
Old 09-28-2009, 07:40   #9 (permalink)
Member: 130995
Please, tell me what model you want to flash exactly so we will be able to tell you what to do.
Old 09-28-2009, 07:50   #10 (permalink)
Member: 720284
Thanks Meter: 13
yes brother i am a new user tel me about the kg270 flash file.brother tell me properle how to recognize the file.for example as a nokia three file mcu ppm cnt mcu big file ppm ae and cnt nai ae please solved my problems
Old 09-28-2009, 07:57   #11 (permalink)
unicomtogo's Avatar
Member: 660737
Thanks Meter: 105
infinity team; always helpful
Old 09-28-2009, 09:08   #12 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
flash file
fIrstly use firmware =KG270P16-07-V10f-XXX-XX-JUN-14-2007+0_firmware[1].B1M
secondly use language file=KG270P16-07-V10f-XXX-XX-JUN-14-2007+0_LP_En_Ru_Ua_Kz_Lt_Lv_Ee[1].B1P
after it click on write option
thanks!!!
Old 09-28-2009, 09:33   #13 (permalink)
Member: 720284
Thanks Meter: 13
Thanks .but tel me firmware file have end of the word bim and language bip.i am right.again thanks thanks.if you dont mind you tel me own yahoo email adrees because next time i take a help with you
Old 09-28-2009, 10:01   #14 (permalink)
Member: 1115989
Sonork: 9905677786
Thanks Meter: 3,202
extension
no brother
firmware = firmware (.bin)
language = LP_En_Ru_Ua_Kz_Lt_Lv_Ee (.lp)
by the way here is my id= [email protected]
thanks!!!!!!!
Old 09-29-2009, 10:30   #15 (permalink)
Member: 130995
KG270P16-AFR-V10d-000-00-JUN-13-2007_firmware.B1M.bin = main firmware
KG270P16-AFR-V10d-000-00-JUN-13-2007_LP.B1P.bin = language pack (LP)
KG270P16-AFR-V10d-000-00-JUN-13-2007_file_system.B1S.bin = phone content (default logo etc)
How to flash lg kp110 in infinity box shivashakthi Infinity-Box 3 12-02-2013 11:39
how to flash lg kg300 with infinity box shahid555 LG Hardware Repair 2 10-31-2008 17:43
How to flash c261 with infinity box Hadiir Motorola Hardware Repair 0 10-18-2008 18:41
Help on how to flash LG u8360 djouaka LG 6 01-25-2008 01:20
Help on how to flash LG u8360 djouaka HWK 6 01-24-2008 23:36
Page generated in 0.29946 seconds with 9 queries
