Old 11-07-2005, 13:50   #1 (permalink)
Member: 74084
Thanks Meter: 8
How to flash Panasonic X70????
Hi at all,
I've an X70 DEAD! I want try to flash it with Infinity Box, but I don't now how?
What Version I must use?
Pls explain me if possible the procedure!
Thanks in advance!
Old 11-07-2005, 14:42   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hi,
Visit support area and download Winmodo.
Also you can find a lot of links to flash files in this forum.
Old 11-07-2005, 18:38   #3 (permalink)
Member: 74084
Thanks Meter: 8
Originally Posted by InfinitySupport
Hi,
But I can use winmodo with Infinity Box? If yes what .exe I must use?
Thanks again!
Old 11-07-2005, 20:27   #4 (permalink)
Member: 130995
Hi,
Winmodo is Winmodo and it's not depends on Infinity-Box.
Old 11-08-2005, 01:25   #5 (permalink)
Member: 74084
Thanks Meter: 8
Hi,
Ok but I want to know if possible to flash my X70 with Infinity Box or not! If positive how pls?!?!?
Thanks
Old 11-08-2005, 12:25   #6 (permalink)
Member: 130995
Hi,
Infinity-Box software don't have X70 flashing support.
You can use original X70 flasher. It's name is "Winmodo".
You can download "Winmodo" from Infinity-Box support area.
You can find flash files for X70 here:
http://vts.vlad.ru/~gsm/Panasonic/Firmware/X70/
Old 11-08-2005, 20:53   #7 (permalink)
Member: 74084
Thanks Meter: 8
Hi,
Thanks friend but this link not work for me!
Another question: What cable I must use? Serial?
Bye
Old 11-08-2005, 21:08   #8 (permalink)
Member: 114797
Thanks Meter: 23
It works using the Universal Box with the Infinity X70 cable. Tried and it works like a charm buddy! Try it!
Old 11-08-2005, 21:10   #9 (permalink)
Member: 130995
Hi,
X70 cable included in Infinity-Box package but if you lost it you can use any other X70 cable (COM port cable or USB-RS232 converter).
Old 11-09-2005, 01:56   #10 (permalink)
Member: 74084
Thanks Meter: 8
Hi,
Yes,
I've Infinity X70 original cable, but where I must insert it? I've only Infinity Box for panasonic! Instead, if i use winmodo where I must insert my cable??
Old 11-09-2005, 09:21   #11 (permalink)
Member: 130995
Hi,
You have to insert it into Infinity-Box like any other cable.
Old 11-09-2005, 16:11   #12 (permalink)
Member: 74084
Thanks Meter: 8
Hi,
My original X70 cable for iNfinity Box is RJ45,
so I must insert it to the box and I must use winmodo!! It's true?
Sorry for more questions!
Old 11-09-2005, 19:28   #13 (permalink)
Member: 130995
Yes, you are 100% right.
Take UniBox from Infinity-Box package (quite big silver or red metal case with several holes and two jumpers).
Take USB cable, connect it into PC USB slot, other end of USB cable connect to small USB hole into UniBox (from Infinity-Box package).
If your PC already powered-on then you will see that some LEDs on UniBox now not dark.
Take X70 cable from Infinity-Box package (you can understand that this is X70 cable by small paper sticker on this cable) and connect it to the left UniBox RJ-45 hole (to find left RJ-45 you have to put UniBox on table and be sure that LEDs is at TOP), both UniBox switches is in UP position.
Go to Device Manager and find correct COM port (that correspond with UniBox).
Now start Winmodo, select correct COM port, select flash files, connect cable to phone, press Flash button and press phone power button.
If you will have any questions don't hesitate to contact us anytime.
Also, about future sucessful Infinity-Box usage:
Go to support area and upgrade your Infinity dongle (use Dongle Upgrade Tools). This can helps you to avoid any problems with latest updates.
Old 11-10-2005, 04:06   #14 (permalink)
Member: 74084
Thanks Meter: 8
Hi Infinity Support,
I've make all your istructions, but when I click on Power button to start flash with winmodo, nothing happen! Programm says only: Sailing...
What I can do?
Old 08-11-2006, 15:49   #15 (permalink)
afrar's Avatar
Member: 95653
Sonork: 100.1585508
Thanks Meter: 110
Talking
What I can do?
THEY SAID SO MANY INSTRUCTION STILL NO UNDERSTAND IF CAN ONE EASY TELL ME YOUR ADDRESS I COME DO OR BUY NEW PHONE AND SEND TO YOU THX
INFINITY TEAM need help how to unlock panasonic X70 jermaineyork Infinity-Box 1 11-22-2009 11:35
how to unlock panasonic x70 fraz12345 Infinity-Box 9 06-11-2009 03:02
How to Flashing Panasonic X70 with infinity alfin5557 Infinity-Box 6 02-06-2009 23:16
how to flash eb-x70 using infinity.? dawgweed Panasonic 1 04-27-2007 14:46
How to flash Panasonic GD 87? Cermis Panasonic 3 11-25-2003 13:26
Page generated in 0.22778 seconds with 10 queries
