Old 07-08-2016, 07:58   #1 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 505
how to flash qmobile i7i ?
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 78 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
PickUp loaders from pac
Old 07-08-2016, 08:35   #2 (permalink)
Member: 2082450
Thanks Meter: 1,429
Need Read info logs.
May be incorrect cpu selected..
The Following User Says Thank You to chandanps18 For This Useful Post:
Old 07-08-2016, 08:48   #3 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 505
Operation : Check/Read Info [ v1.19 ]
3. Insert cable
Phone found! [ 78 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SC773x eMMC v2.0 Loader Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Unknown structure detected! Check correct model selection!
Elapsed: 00:00:26
Reconnect Power/Cable!
Old 07-08-2016, 10:58   #4 (permalink)
Luckey1's Avatar
Member: 2197212
Sonork: N/A
Thanks Meter: 582
As i Know if you Have Infinity Box Read File Then You can Flash .
but with above error you can't read write .
Old 07-08-2016, 12:41   #5 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,905
Hello,
What is phone condition? .pac file selected is for same model or other?
Try with Both Generic and A5 cpu selection, also try with sldr files manually.
Br.
Infinity Box Support Team.
Old 07-08-2016, 14:33   #6 (permalink)
Shani3's Avatar
Member: 1582572
Sonork: 100.1609641
Thanks Meter: 505
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
QMobile i7i Phone Hang On Logo
Old 07-08-2016, 18:28   #7 (permalink)
khanzada606's Avatar
Member: 2455344
Sonork: Ask me
Thanks Meter: 340
read this
qmobile i7i
Old 07-08-2016, 18:31   #8 (permalink)
masterRt1994's Avatar
Member: 2105681
Sonork: Stoped Using...
Thanks Meter: 902
Download Pac Firmware ( Availabel Free On Net ) and Write Firmware or Do Other Operations.
br
masterRt1994
Old 11-11-2016, 06:03   #9 (permalink)
Mubashir999's Avatar
Member: 2570477
Thanks Meter: 419
Also Face this error
Phone found! [ 5 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Old 01-07-2017, 13:31   #10 (permalink)
Member: 2607208
Sonork: 100.1674686
Thanks Meter: 25
i7i boot key with miracle boot jig
Chinese Miracle II [SPD module] v 1.24
Operation : Check/Read Info [ v1.24 ]
3. Insert cable
Phone found! [ 7 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Boot Ver : SPRD 773x eMMC loader v3 Infinity
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FLASH : eMMC Flash , Structure : Ok!
Reading extended info ...
Model Name : QMobile_i7i
Model Brand : Qmobile
Model Device: QMobile_i7i
AndrVersion : 5.1
BaseBand CPU: QMOBILE_I7I
CompileDate : 4/6/2016 9:24:37 AM
Project Ver : QMobile_i7i_MP_06_04
Model Ext : QMobile i7i
ExtraInfo : HWInfo not exists, normal phone
Elapsed: 00:00:29
Old 01-07-2017, 13:35   #11 (permalink)
Member: 2607208
Sonork: 100.1674686
Thanks Meter: 25
i select .pac file when i flash this error
help me
infinity-box team
3. Insert cable
Phone found! [ 7 ]
Port Opened
Sync...
Sync...
Sending FDL
Boot failed!
Boot failed!
Old 01-07-2017, 13:55   #12 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,336
Use cm2spd ver 1.24.
If same - then file not compatible.
Old 01-07-2017, 22:16   #13 (permalink)
zishhaider's Avatar
Member: 952111
Sonork: I'm not using now.
Thanks Meter: 601
It must be your driver issue.. uninstall old drivers.install drivers from support.. and use volume up and down as boot key.. Dont forget to use proper cpu selection from list
Old 01-08-2017, 12:20   #14 (permalink)
Member: 2455344
Sonork: Ask me
Thanks Meter: 340
Fully Supported Here you Go
Qmobile i7i Read Flash Done hardware revision
Old 08-22-2017, 09:07   #15 (permalink)
Member: 2476003
Sonork: 100.1664157
Thanks Meter: 8
hi brothers can any one help me i want to flash Q i7i i can not flash it due to this error
hone found! [ 78 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Page generated in 0.39862 seconds with 7 queries
