10-23-2014, 20:45 | #1 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | Chinese Miracle-2 MTK/MediaTek v1.05 - Nokia 108/130/220/225 support Nokia 108/130/220/225 support MediaTek SP Platform Other: FlashInit improved Compile Info extraction improved FlashID database updated MediaTek FP Platform New CPU/Models supported: Nokia MT625A: Nokia 108 (RM-944, RM-945), Nokia 220 (RM-969, RM-970, RM-971) Nokia MT6260: Nokia 130 (RM-1035, RM-1036, RM-1037), Nokia 225 (RM-1011, RM-1012, RM-1043) Supported Features: Check/Read Info Format FS (Safe Format/Reset Settings) Other: Required to use special drivers for Nokia MTKx phones (uploaded on support) Flash Read/Write is useless due security protection Infinity-Box 9 (nine) years (2005 - 2014) non-stop regular updates and support, as nobody else: Infinity-Box - News New features, Unlock Codes (Huawei, Motorola, Samsung etc.), iPhone Unlock, Software Activations released for Infinity-Box Online Service - World biggest flash files database for several thousands brands/models - BB5 Easy Service Tool [BEST] Dongle - CDMA-Tool Dongle (fast and easy unlock) - Extract phonebook (and other content) from alive and dead phone - Follow us on Twitter |
The Following 17 Users Say Thank You to YellowBoss For This Useful Post: |
10-24-2014, 09:17 | #8 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | You can contact nearest reseller for price or buy in Infinity Online Services any activation for Main Infinity Box and other Infinity products. |
The Following User Says Thank You to Dzirt For This Useful Post: |
10-24-2014, 10:12 | #9 (permalink) | |
I do not think we have to spend a time and move old functions in new software. You can easily run previous versions of Infinity-Box software and repair phones. | |
10-28-2014, 07:51 | #10 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Operation : Read Flash [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D433034475810A20304D037 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D433034475810A20304D037 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : A0 ProdName : A40 ProdModel : A40 Device : A40 AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : G202_GUPAI_K_L_V0.15_20140211_Z23 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__A0__A40__G202_ GUPAI_K_L_V0.15_20140211_Z23__Android_4.2.2__20140 211_125032.ispff Done! Elapsed: 00:15:43 Reconnect Power/Cable! Br. |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
10-28-2014, 13:26 | #11 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Model- Micromax A065 CPU- MT-6571 Read pattern done- Operation : Read PatternLock [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758076775717107 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758076775717107 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... FS Size : 1173 MiB Magic Ok Mount point : /data Get PatternLock ... PatternLock Sequnce : 74269 Done! Elapsed: 00:00:18 Reconnect Power/Cable! Br. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-28-2014, 13:45 | #12 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Model- Micromax A065 CPU- MT 6571 Read full firmware done- Operation : Read Flash [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6571 BB_CPU_HW : CA00 BB_CPU_SW : 8D00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6571_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 7001004D4D4330344758076775717107 DA Stat : v4.2 on BBID : 0x8B DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0070 , OEM : 0100 [eMMC] : FLASH_INF : G40CM [eMMC] : FLASH_CID : 7001004D4D4330344758076775717107 [eMMC] : FLASH_LEN : 0x00000000E6800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info Brand : Micromax ProdName : A065 ProdModel : Micromax A065 Device : A065 AndroidVer: 4.4.2 MTKxCPU : MT6571 MTKxPRJ : MMX_A065_SW_V1.0_HW_V1.0_270614 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6571__MICROMAX__Micr omax_A065__MMX_A065_SW_V1.0_HW_V1.0_270614__Androi d_4.4.2__20140629_075130.ispff Done! Elapsed: 00:17:15 Reconnect Power/Cable! Br. |
10-31-2014, 07:07 | #13 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Micromax X264 CPU- MT-6260 Read Info, Read Flash and Format- Start at : [10/30/2014 / 8:25:39 PM] Operation : Check / Read Info [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 2142564183EC36353F8131AEBE56FE62 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Done! Elapsed: 00:00:03 Reconnect Power/Cable! Finish at : [10/30/2014 / 8:25:43 PM] Start at : [10/30/2014 / 8:25:49 PM] Operation : Read Flash [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 2142564183EC36353F8131AEBE56FE62 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Reading Flash Conent now ... Read Flash now Read Ok , 3145728 bytes read Check and collect compile info File_Info : TINNO60M_QVGA_11B_PCB01_gsm_MT6260_S00.B1100_MP_IN _MMX_V10_00.bin FileVersion : B1100_MP_IN_MMX_V10_00 Saved to : C:\InfinityBox\CM2MTK\Read_out\TINNO60M_QVGA_11B_P CB01_gsm_MT6260_S00.B1100_MP_IN_MMX_V10_00.bin Done! Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [10/30/2014 / 8:26:00 PM] Start at : [10/30/2014 / 8:26:15 PM] Operation : Format FileSystem [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 6 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 2142564183EC36353F8131AEBE56FE62 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : EF00 4000 1600 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00300000 SDS : 0x00000000 , 0x00000000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x002CC000-0x002FFFFF , LEN : 0x00034000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:12 Reconnect Power/Cable! Br. |
10-31-2014, 07:29 | #14 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Kazakhstan
Member: 19032 Status: Offline Thanks Meter: 158 | Copy iPhone 6, MTK 6572 Data from MTK Droid Tool Hardware : MT6572 Model : iphone5s Build number : ALPS.JB3.MP.V1.6 Build date UTC : 20140930-031122 Android v : 4.2.2 Baseband v: MOLY.WR8.W1315.MD.WG.MP.V1, 2014/03/20 16:52 Kernel v : 3.4.5 (fuming@wxt-server) (gcc version 4.6.x-google 20120106 (prerelease) (GCC) ) #1 SMP Tue Sep 30 11:06:35 HKT 2014 Log from v1.05 Code: Start at : [30.10.2014 / 16:21:48] Operation : Read Flash [ v1.05 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 214 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 45010053454D3034472833AA49C710EB DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034472833AA49C710EB [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... USBDL : Skip HSUSB init Read Ok , collect info Brand : Apple ProdName : Iphone ProdModel : iphone5s Device : Iphone AndroidVer: 4.2.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1.6 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6572__APPLE__iphone5s__ALPS.JB3.MP.V1.6__Android_4.2.2__20140930_031122.ispff Done! Elapsed: 02:11:26 Reconnect Power/Cable! I need firmware for this model with russian LP |
