how to force erased wrong flased set Gives error EMI cfg not found |
Hi , Plz post log and also if u have correct firmware do init preloader then do full flash Sent from my S_plus using Tapatalk |
same issue here Quote:
all my telcel firmware log Chinese Miracle II [MTK module] v 1.58 User selected Preloader file : preloader_ztenj72_we_72_m536_kk.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 700100533130303034 , Name : S10004 , Vendor : 70 , [KINGSTON] FlashID [1] CID : FE014E503058585858 , Name : P0XXXX , Vendor : FE , [MICRON] FlashID [2] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [3] CID : 700100454534454134 , Name : EE4EA4 , Vendor : 70 , [KINGSTON] FlashID [4] CID : FE014E50314A393448 , Name : P1J94H , Vendor : FE , [MICRON] FlashID [5] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON] FlashID [6] CID : 700100533130303034 , Name : S10004 , Vendor : 70 , [KINGSTON] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 109 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 1501004E4A325A4D420281C6C4CC33EF Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 42 ] Sync... Inital Boot Ok! BB_CPU_PID : 6583 BB_CPU_NME : [MediaTek] MT6583|6589_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.3.2 on BBID : 0x86 NAND Flash : NOT INSTALLED eMMC Flash : 484A019064314734A2008604DF809C71 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! |
Sent from my Lenovo K50a40 using Tapatalk |
init compatible preloader then phone will act normally. for force you need to find boot pin / kolo point / colo / aka gold point etc. Quote:
Can someone explain with good illustration.. I also have the same issue here |
