Old 06-20-2007, 21:43   #1 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 55
how to format chinese PDA HT508
like in topic ....
i have this chinese PDA [dual sim] HT508 that i want to format [ffs]
how can it be done?
what are the pinouts for this model ? [its an 18 pin connector]
and could any one confirm if these pinouts for infinity box is correct or not
1-Vpp
2-Tx
3-Rx
4-RTS
5-CTS
6-M-Bus
7-GND
8-GND
please help me find out what are this phone pinouts
thanks in advance
Old 06-21-2007, 13:33   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Pinout: http:///vbb/showthread.php?t=342807
How to format: if this phone has MT62xx CPU inside run "ChineseMiracle" software and make "format ffs"
Old 06-21-2007, 14:24   #3 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 55
you just answred half of the question....
pinouts PLEASE
i checked box pinouts, and its ok
but what about phones pins Rx and Tx ??
one more thing
i have the usb cable which comes with the phone
it is used for charging and data transfer
it has
1-GND
2-GND
11-USB
12-USB
16- +
17- +
18- +
i tried lines from 3-10
could not find the correct combination of Tx and Rx
thanks
Old 06-21-2007, 15:56   #4 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 55
ok finally found it
7 and 9 are the tx and rx 1 is ground
solved by FFS format
COM5 [VCP0] selected
Device: Autodetect
Checking data, wait...
advanced flash detection active
Action: reset
Boot...
baud autodetection active
19200
Connecting, wait...
Initializing[6226:8A02:8A01]...
Release Power button now !
Boot Done
Initialize...
flash: EC257E25082501:29EA0000000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
Initialize Done
Set baud...
230400
Set baud Done
Check space...
operation mode: Fast detection mode
device parameters autodetection in progress..
total flash region size: 01000000
detecting eeprom area in 1 chip(s)...
checking area[00000000]: 00000000-00FFFFFF...
eeprom found near: 00E00000
detecting eeprom size...
eeprom size: 00200000
eeprom chip: 00
eeprom area detected[00000000]: 00E00000-00FFFFFF
detect device identification, method #1...
detection phase #1...
protocol version: 0004
2nd [enhanced] (or higher) generation model detected
Attention: read full flash backup before any action !
identification data Ok
identification data backup saved: id.7B6B1ECE.[E553_Z4_E553_GPRS_MT6226_S01.01_1.BIN_42E3FDDC].rpl
identification detection finished
device-id: 7B6B1ECE
version sw1: E553_Z4_E553_GPRS_MT6226_S01.01_1.BIN
version sw2: E553_Z4.01.1
detection phase #3...
detect device parameters finished
reading [eeprom[E553_Z4_E553_GPRS_MT6226_S01.01_1.BIN]]...
file saved: backup_eeprom[E553_Z4_E553_GPRS_MT6226_S01.01_1.BIN]_20070621-065806.B0E.bin
Check space Done
Manipulation...
Manipulation Done
Finalization...
Finalization Done
Write...
formatting...
Write Done
file saved: backup_system_log_7B6B1ECE_[E553_Z4_E553_GPRS_MT6226_S01.01_1.BIN]_42E3FDDC_20070621-065822.B0X.bin
Finished, time used: 240 sec
Remove/Install battery now !
The Following User Says Thank You to mansi For This Useful Post:
Old 06-21-2007, 23:00   #5 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Thanks for sharing the pinouts.
Can you please tell me what was the problem before?
Old 06-23-2007, 15:12   #6 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 55
when you power on the phone with SIM card inside it restarts all the time
maybe (virus infection).
it was solved by format.
best regards
Mansi
Old 06-23-2007, 21:04   #7 (permalink)
nishaon's Avatar
Member: 225229
Thanks Meter: 90
Yes, format solves many problems
Old 06-24-2007, 09:41   #8 (permalink)
kaino147's Avatar
Member: 53891
Thanks Meter: 35
best regards
Mansi
Pls can u tell me how u tested for tx and rx??? Another question is, is it the usb cable u modified or unibox cable?
Old 06-27-2007, 17:37   #9 (permalink)
mansi's Avatar
Member: 8664
Sonork: 100.1573507
Thanks Meter: 55
what is the phone you are trying to repair ?
and its not a usb cable its an (m-bus) RJ45 cable (like the ones u use with universal box) i used a (samsung A300 connector) which i had from an old Tornado box i cut the connector and solderd the 3 wires inside.
check the FAQ to check how can u find pinouts
by the way......
check the pinouts for other models with same connector it might be the same as the phone you have right now.
Old 05-13-2008, 12:01   #10 (permalink)
Member: 771371
Hi,
Iam using CECT HT-508. Can u tell me how long this phone lasts. I was using the bluetooth faculity in this phone and suddenly the phone went blank and the whenever i start the phone it starts and again went balnk and again starts and that process continues.But if i remove the sim card then i can access all other features in the phone.
Can you tell me how 2 fix this problem? Is there any website for this phone?
Old 05-13-2008, 12:32   #11 (permalink)
Member: 148515
Thanks Meter: 14,904
hello mr. TED_LAMPROS!
this phone must be formated
Old 05-17-2008, 19:12   #12 (permalink)
Member: 771371
Then dont i have to install the operating system in the phone again.Can u tell me where i can find the operating system?
Old 05-17-2008, 20:55   #13 (permalink)
Member: 148515
Hello!
i can only advice how to reapir this phone by infinity box software
how to format N73 chinese Miracle??? elkawasmy Infinity-Box 25 10-11-2009 18:56
how to format chinese bluetooth n98 mukasa Infinity-Box 1 06-14-2009 12:30
How to convert chinese file of differnt format to infinity format? rangeric Infinity-Box 8 10-03-2008 20:49
format 2nd CPU on chinese PDA HT508 jokkergsm Infinity-Box 11 05-27-2008 14:50
How to format chinese Infieon CPU ajaystarin Chinese Models & Cloned Phones 4 05-26-2008 13:10
Page generated in 0.42220 seconds with 8 queries
