Old 03-09-2007, 16:53   #1 (permalink)
Member: 321452
Thanks Meter: 9
how to gd55 imei change
how to gd55 imei change to ınfınıty box
Old 03-09-2007, 18:44   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
start program, go to "service" tab.
write imei , push "repair" imei.
if desired imei is impossible to set, pick other imei from list which will apear/.
thats it!
Old 03-11-2007, 17:28   #3 (permalink)
Member: 321452
Thanks Meter: 9
thanks best regards...
Old 02-07-2008, 12:07   #4 (permalink)
hans salim's Avatar
Member: 292087
Sonork: 1575183
Thanks Meter: 194
@bro infinity
plz where is software for gd55 imei change?,i cant find in support area and which cable i can use?
Old 02-07-2008, 12:34   #5 (permalink)
Member: 130995
Thanks Meter: 35,227
Dear Friend,
Please, run Infinity-Box Shell, select model GD55 and you will be really surpriced with results.
Old 02-07-2008, 19:29   #6 (permalink)
hans salim's Avatar
Member: 292087
Sonork: 1575183
Thanks Meter: 194
it show application not found,i try to run QCMODULE but i cant see panasoni
Old 02-07-2008, 21:18   #7 (permalink)
Member: 130995
You must run QModule.
if you can't find it on your HDD you need to download it from support area.
Old 02-08-2008, 05:15   #8 (permalink)
hans salim's Avatar
Member: 292087
Sonork: 1575183
Thanks Meter: 194
thanks i found after install v2.11a,but what is a cable for gd55 i try gd50 cable is not working?
Old 02-08-2008, 07:10   #9 (permalink)
Member: 130995
special GD55 cable is included in Infinity-Box package.
Old 02-11-2009, 21:02   #10 (permalink)
jufong's Avatar
Member: 120908
Thanks Meter: 38
for gd55 u must solder the board pcb
difrent for a100
Old 02-12-2009, 20:28   #11 (permalink)
Member: 130995
Hello,
Special GD55 cable is included in Infinity-Box package.
You can get more information here: http://forum.gsmhosting.com/vbb/showthread.php?t=388717
how to EL71 imei change turkcellgsm x6x and x7x Flashpatching 2 11-02-2008 09:22
how to C75 imei change with dream box pls help me... HEDEF_GSM DreamBox 2 12-22-2006 19:33
elco how to unlock + imei change on X650 ? cellularman NSPRO 2 11-01-2006 20:10
how to G5400 imei change???? repraky LG 0 01-15-2005 23:49
How to do IMEI change in GD92 and 93? Burnt Cobba Panasonic 4 09-25-2002 08:04
Page generated in 0.41740 seconds with 10 queries
