09-08-2007, 12:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 139388 Status: Offline Thanks Meter: 98 | How to identify chinese model The bottom charging connector is compact with samsung R220 flashing cable How to identify which pin is RX and Tx in the bottom connector Phone is dead now |
09-08-2007, 12:28 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: C:\Program Files\
Member: 187451 Status: Offline Thanks Meter: 163 | its better to give full information about the phone.check its chip first then connectory type.write in fiigures like how much pins it got.and tell its gnd. |
09-08-2007, 19:29 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | @celluniversal How to find pinout for unknown model Please, follow instruction exactly like described below In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model: 1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location) 2. find Charge pins (it's optional step, just to save your time during future research) 3. find +Battery pins (it's optional step, just to save your time during future research) 4. connect cable Gnd to phone Gnd 5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone 6. if flash read procedure can start this means that pinout found Ok and you can make other operations Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models" it's good idea to find correct pinout according to above instruction and send new pinout information with full text from phone back label to [email protected] |
09-11-2007, 00:53 | #5 (permalink) | |
How to find pinout for unknown model Please, follow instruction exactly like described below In most cases you need to know Gnd, Rx, Tx pins for flash/unlock operations. What do do if you don't have cable or you have new phone model: 1. find Gnd pin (it's required step, you can't continue until you will know Gnd pin location) 2. find Charge pins (it's optional step, just to save your time during future research) 3. find +Battery pins (it's optional step, just to save your time during future research) 4. connect cable Gnd to phone Gnd 5. try to connect cable Rx/Tx wires to all phone contacts one by one (except Gnd, Charge, +Battery pins) and try to read flash from phone 6. if flash read procedure can start this means that pinout found Ok and you can make other operations Note about "Chinese models": a lot of different phones with the same name exist on market (as well as many different name phones with the same pinouts), so, if you see in our "cable selector" wrong pinout for "Chinese models" it's good idea to find correct pinout according to above instruction and send new pinout information with full text from phone back label to [email protected] | |
how to identify parts from CP connecting to GPRS pls. | venuno | Nokia Hardware & Hardware Repair | 0 | 11-20-2009 08:34 |
how to add chinese in these 2 model | kkio | Motorola P2k | 3 | 07-29-2008 13:35 |
Supported phone model list and how to identify cpu type? | jham | MC-Tool | 0 | 01-02-2008 14:51 |
How to identify BE20 | ab1009 | x1x to x45/x50 | 1 | 10-02-2002 19:31 |
How to identifie SAGEM's new phones ???? | baypierre | Infineon C16X M51 & ARM7 M52 BASED | 0 | 03-14-2000 14:32 |
