10-04-2007, 17:28 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Algeria
Member: 329483 Status: Offline Sonork: 100 Thanks Meter: 443 | How To Inter Unlock Code For Lf Kg275 Device: LG KG275 Checking data, wait... Action: unlock read unlock codes Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL FR SFR KG275 P16 FL 33 V10a 208-10 JUN 22 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_20071004-172023.B1E.bin loading data... data loaded imei: 35744501713288300 Reading [eeprom-sec_35744501713288300]... file saved: backup_eeprom-sec_35744501713288300_20071004-172024.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 86967595 Finished, Remove/Install battery now ! Time used: 14 sec PLEASE HELP ME TO INTER UNLOCK CODE |
The Following User Says Thank You to ..::khaled::.. For This Useful Post: |
10-04-2007, 20:27 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 37
Member: 141164 Status: Offline Thanks Meter: 36 | when u put sim card which dont work with the phone it say insert correct sim card.so there must be a way to enter the code which still unkown as far as i know. today i tryed to unlock same fone which was working with the orange uk, fone got unlocked with direct unlock method 2 when i put another network sim card its show network logo with full respection,but when i try to call customer service the call not going through and its say call end. i put the orange sim card fone works with it. can u plz tell us wat is going wrong with problem thanks infi team for all ur help. |
10-04-2007, 20:35 | #4 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | @ Naz66 try with direct unlock and select (direct unlock method #1) after that make full factory reset 2945#*# without sim inside |
10-04-2007, 23:55 | #5 (permalink) |
No Life Poster Join Date: Nov 2004
Member: 91102 Status: Offline Thanks Meter: 34 | Kg275 Doesn't Ask For Codes Put Any Wrong Sim In Phone Phone Will Say "insert Correct Sim" Type The Unlocking Code And Press Call "green" Button Wait For Few Seconds Phone Will Restart And Is Unlocked |
The Following 4 Users Say Thank You to chowdary For This Useful Post: |
10-09-2007, 23:53 | #8 (permalink) |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | hello flash with this FW, KG275P16FL-351-V10b_268-06_MAY-29-2007+2_firmware.B1M.bin KG275P16FL-351-V10b_268-06_MAY-29-2007+2_LP_En_Es_Pt.B1P.bin works for me good luck!! |
10-11-2007, 12:52 | #11 (permalink) |
Member: 141164 Status: Offline Thanks Meter: 36 | Today I Try To Unlock Kg275 And I Noticed That With Procedure Of Unlocking It Change The Imei No.of Phone Fone Got Unlocked But Its Only Working With Orange Uk But With Another Sim Card When I Call Customer Serviec Fone Say Call End. Now Question Iz If Repire Imei Does The Recored Will Stay In My Pc Cuz I Never Change Or Repired Imei Of Fone.cuz I Respect The Law. We Will Be Thank Full Infinity Team If U Plz Cheak This Problem Why Fone Imei Got Changed In Process Of Unlocking Persnaly I Dont Like This Kind Of Solution. |
11-02-2007, 12:11 | #15 (permalink) |
No Life Poster Join Date: Nov 2005 Location: work Age: 11
Member: 195993 Status: Offline Sonork: 100.1653595 Thanks Meter: 128 | [quote=chowdary;2768398]Kg275 Doesn't Ask For Codes Put Any Wrong Sim In Phone Phone Will Say "insert Correct Sim" Type The Unlocking Code And Press Call "green" Button Wait For Few Seconds Phone Will Restart And Is Unlocked[/quote thanks regarding entering code for unlocking and entering the green button... regrads THE KOP... |
The Following User Says Thank You to mint centre For This Useful Post: |
How to inter unlock code k1 plz help | sajidashraf | Motorola P2k | 4 | 10-20-2009 16:40 |
How to inter unlock code for alc ot-v570? | ..::khaled::.. | Alcatel TCL Phones and New Models | 0 | 02-20-2009 17:41 |
How to enter unlock code for mitsibushi m341i | anis76 | Mitsubishi | 3 | 08-03-2006 11:47 |
how to enter unlock code for siemens s56????? | wingh2daizzo | Phone Unlocking Codes & Maps | 17 | 10-24-2003 17:47 |
How to calc unlock codes for new tool? | gsmsalers | Infineon C16X M51 & ARM7 M52 BASED | 4 | 07-15-2003 16:39 |
