11-05-2007, 15:11 | #16 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | COM1 [Serial0] selected Device: LG KG275 Checking data, wait... Action: unlock read unlock codes Boot... Press Power button now ! Checking... boot answer: 01 Boot Done Set Baud... Set Baud Done Connecting... flash: 0001:011A Connecting Done Check free space... flash chip supported sw version: ULC2GL FR SFR KG275 P16 FL 33 V10a 208-10 JUN 22 2007 +0 Check free space Done Check parameters... Check parameters Done backup critical area... Reading [eeprom-sta]... file saved: backup_eeprom-sta_200xxx05-06xxx.B1E.bin loading data... data loaded imei: 35xxxx601966xxxxxx Reading [eeprom-sec_357446xxxxx89000]... file saved: backup_eeprom-sec_35xxx01966xxxxx_20071105-060409.B1E.bin backup critical area Done Check memory... loading data... data loaded code: 48210807 Finished, Remove/Install battery now ! Time used: 26 sec Thnx Infinity Team B.R khemal |
11-17-2007, 10:20 | #20 (permalink) |
No Life Poster Join Date: Apr 2001 Location: IN CASTLE Age: 46
Member: 3925 Status: Offline Thanks Meter: 22 | hi guys which soft do you use for unlock kg275 ??? i can't find help me ???? in lg module no kg275 model ....................... help me thanks a lot |
11-17-2007, 20:05 | #21 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Please, run "Infinity-Box Shell", select model "LG KG275" and you will be able to start correct module automaticaly, no need to search what module should be used for what model. | |
11-19-2007, 11:27 | #22 (permalink) |
Member: 3925 Status: Offline Thanks Meter: 22 | sorry i'm select kg275, but allways satarting panasonic module..................................... help me where is kg275 unlock soft??? help me thanks a lot |
11-19-2007, 17:31 | #26 (permalink) | |
You need to download and install latest updates. of course old moduled don't have new models and you must download and install new software modules to see new supported models. | |
11-19-2007, 19:21 | #28 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,229 | |
11-19-2007, 20:02 | #30 (permalink) |
Member: 3925 Status: Offline Thanks Meter: 22 | problem solved. i'm find kg275 unlock soft infinity last version is v2.10a right ? but support section not working................................. thanks a lot |
How to inter unlock code k1 plz help | sajidashraf | Motorola P2k | 4 | 10-20-2009 16:40 |
How to inter unlock code for alc ot-v570? | ..::khaled::.. | Alcatel TCL Phones and New Models | 0 | 02-20-2009 17:41 |
How to enter unlock code for mitsibushi m341i | anis76 | Mitsubishi | 3 | 08-03-2006 11:47 |
how to enter unlock code for siemens s56????? | wingh2daizzo | Phone Unlocking Codes & Maps | 17 | 10-24-2003 17:47 |
How to calc unlock codes for new tool? | gsmsalers | Infineon C16X M51 & ARM7 M52 BASED | 4 | 07-15-2003 16:39 |
