07-01-2015, 17:32 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | Read Factory File Failed ;( 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 54 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 00AD00BC00900055005600AD00BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0094 , [Acsip] A5R4GA41ATS [NAND] : FLASH_DIE : 00AD 00BC 0090 0055 0056 00AD 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Not supported FlashType for this operation yet Done! Elapsed: 00:00:07 Reconnect Power/Cable! read full flash bin ok Reading Flash Conent now ... Read Ok , collect info MTKxCPU : MT6572 MTKxPRJ : huaqin72_we_b2a_gb3 Saved to : C:\Users\Umar\Desktop\MT6572__huaqin72_we_b2a_gb3. ispff Done! Elapsed: 00:03:45 Reconnect Power/Cable! |
07-01-2015, 17:49 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Due NAND structure it not supported yet. In some near version will be added. Still not finished correct UBIFS defrag. Small count of samples make problems. |
