11-04-2016, 10:32 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Nokia X2 , MSM8610 (original) : Read / Write firmware and etc ;) Code: Operation : Identify [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 01FE647B ID_BLOCK_I : 008110E1 ID_BLOCK_L : 189797909E83BB0C ID_BLOCK_L : A9EB81EB51517B85 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Nokia AndroidVer: 4.3 Manufact. : Nokia QLMxCPU : MSM8610 Done! Elapsed: 00:00:33 Read FW : Code: Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 01FE647B ID_BLOCK_I : 008110E1 ID_BLOCK_L : 189797909E83BB0C ID_BLOCK_L : A9EB81EB51517B85 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Nokia AndroidVer: 4.3 Manufact. : Nokia QLMxCPU : MSM8610 DevInfo : MSM8610__Nokia__Nokia__ANDR_v4.3 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : rpm.mbn [Read Ok] : boot.img [Read Ok] : tz.mbn [Read Ok] : persist.img [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : recovery.img [Read Ok] : custom.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 912 MiB Done! Elapsed: 00:02:15 Reconnect Power/Cable! Code: Loading firmware ... Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : Nokia Device Manufact.: Nokia Device CPU : MSM8610 Device Version : 4.3 CU_SWVer : Nokia Device Compile : 27.06.2014 11:52:37 Load Ok! Operation : Flash [ v1.02 ] Verify FW package ... Verification passed! 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 01FE647B ID_BLOCK_I : 008110E1 ID_BLOCK_L : 189797909E83BB0C ID_BLOCK_L : A9EB81EB51517B85 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Files in Chain : 21 Flashing now Flashing : gpt_main0.bin Flashing : NON-HLOS.bin Flashing : sbl1.mbn Flashing : sbl1.mbn Flashing : deploy.mbn Flashing : emmc_appsboot.mbn Flashing : emmc_appsboot.mbn Flashing : rpm.mbn Flashing : rpm.mbn Flashing : boot.img Flashing : tz.mbn Flashing : tz.mbn Flashing : persist.img Flashing : system.img Flashing : cache.img Flashing : recovery.img Flashing : custom.img Flashing : userdata.img Flashing : gpt_backup0.bin Flashing done! Done! Elapsed: 00:03:13 Code: Operation : Reset Settings [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 01FE647B ID_BLOCK_I : 008110E1 ID_BLOCK_L : 189797909E83BB0C ID_BLOCK_L : A9EB81EB51517B85 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Format USER ... Format CACHE ... Format Ok! Done! Elapsed: 00:00:28 |
The Following 13 Users Say Thank You to JayDi For This Useful Post: |
11-04-2016, 12:46 | #9 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Sure, it better. But need leave chance for those, who not have BEST | |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
11-05-2016, 14:57 | #12 (permalink) |
Freak Poster Join Date: Dec 2008 Location: cebu city
Member: 920138 Status: Offline Thanks Meter: 97 | please add thise model in next update.. Infinity-Box Qualcomm Module [QLM] v 1.02 Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 011C9F95 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Cherry Mobile ProdName : Nova 2.0 ProdModel : Q710 Device : msm8610 AndroidVer: 4.3 Manufact. : Cherry Mobile QLMxCPU : MSM8610 DevInfo : MSM8610__Cherry_Mobile__Cherry_Mobile__ANDR_v4.3__ Q710__msm8610__Nova_2.0 ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-05-2016, 15:02 | #13 (permalink) |
Member: 920138 Status: Offline Thanks Meter: 97 | please add this model in next update. Cherry mobile Omega Icon Operation : Read Flash [ v1.02 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 05E4A9B8 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 49C762F6FE52E492 ID_BLOCK_L : 9B939302A85331CC Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , VER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Cherry Mobile ProdName : Omega Icon ProdModel : H700 Device : msm8610 AndroidVer: 4.3 Manufact. : Cherry Mobile QLMxCPU : MSM8610 DevInfo : MSM8610__Cherry_Mobile__Cherry_Mobile__ANDR_v4.3__ H700__msm8610__Omega_Icon ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log Info : Device is not supported yet! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
11-05-2016, 16:30 | #14 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @ninozacal, connect device for read FW again. Any of those 2. Save file from ReportFile : C:\InfinityBox\CM2QLM\QLM_report.log to another place. Or pack it to archive as, example : msm8610__Omega_Icon Connect second device and do same for it. Bothj files are very small and you can upload them fast. As soon as you send me files - you will get update. |
11-05-2016, 19:33 | #15 (permalink) | |
Member: 920138 Status: Offline Thanks Meter: 97 | Quote:
