08-22-2009, 16:28 | #1 (permalink) |
No Life Poster Join Date: Apr 2005 Location: Gsmhosting Age: 47
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | china miracle 2.90..touch calibaration new method not working. always verification failed..tried on two sets.. COM5 [VCP0] selected module v2.90 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... TYM072642_615_PCB01_GPRS_MT6226_S01.072642_615_V12 21__fullflash_20090822-204631.B0M.bin loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:8841:8A60 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 072642_615_V1221 Version: TIANYU26_06A_HW 42 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 147 byte(s) read 664 byte(s) read writing data... verification... error: verification failed Finished, time used: 11 sec Remove/Install battery now ! COM5 [VCP0] selected module v2.90 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... GINWAVE25_GEMINI_PCB01_GPRS_MT6225_S00.FXD-S3PLUS-ML07_MR106_001_5S-14-16-77518_V1_1_023_080913__fullflash_20090822-202450.B0M.bin loaded detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A03:8A00]... CPU: MT6225 high speed boot On chip: 0001:2003:0007 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6225,E03 Date: 2006.06.14 Version: 1.0 Version: FXD-S3PLUS-ML07_MR106_001_5S-14-16-77518_V1.1.023_080913 Version: GINWAVE25_GEMINI_HW 67 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 211 byte(s) read reading data #2... 512 byte(s) read writing data... verification... error: verification failed Finished, time used: 16 sec Remove/Install battery now ! |
08-22-2009, 16:40 | #2 (permalink) |
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | but old method with older version of china miracle works after several tries. COM5 [VCP0] selected module v2.85 Action: touchscreen calibration mode: 1 Calibration order: reverse Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:8841:8A60 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 072642_615_V1221 Version: TIANYU26_06A_HW detecting structure #2... 0 done 42 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok detecting structure #5 (mode-1)... 19 18 done 147 byte(s) read reading data #2... writing data... verification... verification Ok Power-On and test phone now If calibration is not completed yet: 1. make "Reverse calibration order" UN-checked and try again 2. try another calibration mode Finished, time used: 16 sec Remove/Install battery now ! |
08-22-2009, 19:32 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, In this situation you need to repeat calibration several times or make this: - make "format ffs" in "complete" mode - Power-On phone - Power-Off phone by "Power" button (do NOT remove battery) - Repeat "Calibration" operation again - if still no luck read full flash and send to support with subject: touchscreen calibration failed |
08-22-2009, 20:05 | #4 (permalink) | |
Freak Poster Join Date: Jul 2009 Location: Pakistan Age: 39
Member: 1074634 Status: Offline Sonork: 100.1583894 Thanks Meter: 241 | Quote:
ya its 100% right if its not done in one chance u try many time at last u see ur phone is ok i try many time | |
08-23-2009, 10:50 | #5 (permalink) | |
Member: 142191 Status: Offline Sonork: 100.1589775 Thanks Meter: 297 | Quote:
COM5 [VCP0] selected module v2.90 Action: touchscreen calibration How to calibrate touchscreen: - for this operation you need to have full flash backup from phone - if you have full flash backup already press "Yes", select full flash file and follow instructions given by software - if you do not have full flash backup yet press "No", read full flash and repeat calibration procedure Do you have full flash backup ? Loading file v.02... TYM072642_615_PCB01_GPRS_MT6226_S01.072642_615_V12 21__fullflash_20090822-204631.B0M.bin loaded detected record size adjusted detected record size adjusted detected record size adjusted Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:8841:8A60 status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226,E02 Date: 2005.04.12 Version: 1.0 Version: 072642_615_V1221 Version: TIANYU26_06A_HW 42 byte(s) read imei: 13579024681122 warning: current phone imei is incorrect ! It's need to repair imei for correct phone functionality ! connection Ok 147 byte(s) read reading data #2... 512 byte(s) read writing data... verification... verification Ok Finished, time used: 12 sec Remove/Install battery now ! | |
