11-11-2015, 21:17 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | how to read 4 digit on vodaf smart 4 mini thank you |
11-12-2015, 22:26 | #3 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Operation : Check / Read Info [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 173 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:05 Reconnect Power/Cable! if y format fone will y not luse data inside sir.JayDi??y want to extract data. cheers |
11-12-2015, 22:41 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I advise start from learning basics : What mean termins : Format, erase, user data , what mean MTK FP and MTK SP , how what and when possible do need operations. After - back with questions. |
11-13-2015, 11:30 | #5 (permalink) |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | sir...y dont whant to format the fone....only y need is to now if 4 digit pin lock is possible to read wethout format fone. n |
11-14-2015, 19:21 | #7 (permalink) | |
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Quote:
Operation : Clear UserLocks [Pin/Pwd/Pattern/FVLock/GoogleAcc] [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 173 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : d1G4 [eMMC] : FLASH_CID : 90014A4834473164048600D3BD2050B3 [eMMC] : FLASH_EXT : 00200000/00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! LSSA Ok! LSSW Ok! LSSS Ok! LSSG Ok! LSSK Ok! Security Settings : Clear Ok! [Info] : Android 5.x / MT67xx : If phone stuck on "Logo" 1. Wait 2-3 minutes. Power Off phone by long press "Power" button 2. Power On phone again 3. Or wait up to 3-7 minutes, until phone start by itself 4. Also recommended reboot phone twice before start use it Done! Elapsed: 00:00:20 Reconnect Power/Cable! thanks to JayDi | |
