03-10-2009, 11:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: ROMANIA
Member: 188484 Status: Offline Thanks Meter: 117 | How to read flash MT6235? Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6235, E04 Hardware version: RATECH35_08A_HW Software version: X8_XZY_MLB_1_6T07S01 Software date: 2000.00.00 Barcode: MT012345678901234567 imei: 357000008011931 imei: 357000008011434 Finished, time used: 5 sec Power off phone now ! I need for editing language. |
The Following User Says Thank You to alunecosu_hd For This Useful Post: |
03-12-2009, 09:38 | #5 (permalink) |
Member: 188484 Status: Offline Thanks Meter: 117 | COM4 [VCP0] selected module v2.78 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read NOR flash Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... error: can't detect CPU id Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 23 sec Remove/Install battery now ! baudrate 115200 and more.... |
06-01-2009, 07:32 | #15 (permalink) |
Major Poster Join Date: Jan 2003 Location: Ukraine, Kharkiv Age: 43
Member: 20554 Status: Offline Thanks Meter: 1 | hi all here is pinout for datacable (pl2303) you can modify samsung d500 cable count pins when you look on connector from left to right 8 - Тx 9 - Rx 17+18 - GND you can use FlashTool_v3.0840.00 to read\write flash set operations method NFB there are 2 firmware vesions i know last X8_XZY_MLB_1_7T08S0309 2009/03/09 master full can be found here http://rapidshare.com/files/23600470..._Pavel.7z.html to update firmware you need to load scat_6235_Pavel.txt (Scatter-loading ) after flash make reset for factory settings password 1122 |
How to read flash from Withus WCE-100? | dennt | Various CDMA/TDMA Cell Phones | 13 | 05-07-2007 17:33 |
How to read Flash and send them to support??? | byteforce | Cruiser Suite | 2 | 06-03-2006 13:25 |
how to read flash to a-840 ? | smso | Motorola P2k | 0 | 05-23-2006 10:10 |
how to read flash to d-500 | smso | SWIFT Platform | 5 | 06-22-2005 20:31 |
How to read flash from S300 to file | Birisx | Trident/AGERE Platform | 0 | 07-22-2003 09:15 |
