-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   how to read spd pac file help me (http://forum.gsmhosting.com/vbb/f296/how-read-spd-pac-file-help-me-2230047/)
skgrxl 06-01-2017 05:55
hare is cm2 spd log:-
Card found: S/N : 1AFA746B , v0136
Chinese Miracle II [SPD module] v 1.26
Set mode to : SP [SC773x] eMMC [Android 6.x]
Operation : Read FullFlash [ v1.26 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
3. Insert cable
==== Wait for phone...
Phone found! [ 18 ]
Port Opened
Sync...
InitBoot Done [ 0x81 ] , Ver : SPRD3
Sync...
Sending FDL
[Info] : If SW freeze here more, than 15 seconds - remove cable
FDL Ready!
Boot Ver : SC7731 Crev eMMC Loader v2.0
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Detected eMMC Flash , Structure detect Ok!
[FW_READER] : Prepare Ok!
- > Wait phone connected ...
Device boot not done
Check Drivers
Try again
[FW_READER] : Step #2 Failed!
Error_Info : Initial Boot not done! Check Driver and connection, charge battery!
Reconnect Power/Cable!
Operation : Format File System / Reset Settings [ v1.26 ]
Settings : SmartFormat is On
3. Insert cable
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Checking Structure ...
eMMC phone detected! Will use 'Safe Format' mode!
Mount : /data
State : 0x0001
Mount : /cache
State : 0x0001
Prepare Ok! Format Ok!
Don't touch phone, until it fully bootup to "Welcome Screen"!
Android 5.x/6.x : Reset FRP Lock
Reset Ok!
Done!
Elapsed: 00:00:50
3. Insert cable
Phone found! [ 151 ]
Port Opened
Sync...
Initial Boot Failed!
Boot not done, reason : Wrong BootKeys
Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down )
3. Insert cable
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
Check Drivers
Try again
3. Insert cable
Check Drivers
Try again
3. Insert cable
Phone found! [ 18 ]
Port Opened
Sync...
Sync...
Sending FDL
FDL Ready!
Sending FLASH FDL
FLASH FDL Ready!
Boot Ok!
FlashMode Set : Ok!
Port Opened
Sync...
i try to many times but no luck please make a gif pic or video to how read spd file
netvision123 06-01-2017 08:38
Bro here is your requested video.
https://www.youtube.com/watch?v=NoQ3Tvmw7Vw
watch it carefully and also watch related video for creation of .pac file
in some new handset you don't have to press both vol+ and vol- key together
just Volume + key is enough to connect the phone.
Hope will help you .. or you may also try this manual for gaining more knowledge
Index of pub//manual/ChineseMiracle2/
skgrxl 07-10-2017 17:27
Thanks now i read spd file with cm2spd
Sent from my Redmi Note 3 using Tapatalk
Page generated in 0.16229 seconds with 5 queries
