07-01-2015, 10:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2012 Location: vietnam
Member: 1781157 Status: Offline Sonork: 100.1624851 Thanks Meter: 167 | how to read write fomat 6595 ] v 1.21 Operation : Check / Read Info [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 52 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage SecCfgVal : 0x07000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Error : Correct DA sequence not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Fix DL Errors [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 52 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:03 Reconnect Power/Cable! Operation : Fix DL Errors [ v1.21 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 52 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6595 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6595_S00 Processing BROM stage SecCfgVal : 0x07000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage Error : Correct DA sequence not found for target! Try Re-Install CM2MTK module! Boot Error! Operation Failed Elapsed: 00:00:02 Reconnect Power/Cable! |
