03-10-2008, 12:58 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ES-Brazil
Member: 217679 Status: Offline Thanks Meter: 95 | How to record flash backup W220? Bruno |
03-10-2008, 16:56 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Please, read 1. General IMPORTANT information (you can skip rest info, but read this please) in Infinity-Box user manual: C:\Program Files\InfinityBox\Documentation\Infinity-Box_UserManual.htm [email protected] Please, before send to us any files check, that this flash file is not exist in support area already. |
03-10-2008, 21:53 | #3 (permalink) | |
Member: 217679 Status: Offline Thanks Meter: 95 | Quote:
http://rapidshare.com/files/98539070/backup_motorola_w220.zip.html | |
03-12-2008, 13:23 | #8 (permalink) | |
Charles | |
03-12-2008, 14:00 | #9 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, If you have problems with phone after flashing you need to use another flash files: Main + Lp + Flex + Images + Melody How to select correct files sets: C:\Program Files\InfinityBox\Documentation\Infinity-Box_FlashFilesDescription.htm Also there is a thread regarding white screen problems: http://www./showthread.php?t=409828 Last edited by InfinitySupport; 03-12-2008 at 14:11. |
03-12-2008, 14:41 | #10 (permalink) | |
Friend I sent a flash backup of a device you to decide the problem of this archive therefore I did not obtain to play this flash above backup for the in agreement device the topic, then I only received 1(um) archive w220_SCA-7-115A_0331-013_0357-181_0241-021_0230-006_main_lp_flex_images_melody_Vivo1[1].6AM I played this archive in the device and the device alone presents the problem with white display when I place card, without card it is not with white display more asks for to insert card, I find that the problem must be in the flash file that you of the support sent. Charles Bruno | |
03-12-2008, 15:18 | #11 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, File that I have sent you contain all required firmware parts together: Main + Flex + LP + Images + Melody. If phone can Power-On without card this means that phone software is good. Did you tried to insert another sim-card ? Did you tried to check phone hardware ? Did you tried to flash phone with another files from support area ? |
03-12-2008, 15:40 | #12 (permalink) | |
I tried yes with other flash of the support, I tested others card and also of the same error some flash appears the message in the viewfinder of the Unauthorized device phone, and some flash of the support the device nao presents no error and functions correctly, and the 06 flash backup that it sent me when I remove card and I type *#06# does not appear the number of imei is blank the data of imei. The problem is that necessary very of the flash backup that I sent you of the alive operator in Brazil with the frequency 850mhz that is the device that I am here and the flash of the support of infinity all are 900mhz. | |
03-12-2008, 18:14 | #15 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I can't understand how it was happened that after flashing only with firmware phone lost imei. Please, use "repair_eeprom" files and make "Repair" again after flashing phone with "repair eeprom" file. |
how to make cable for w220 to unlock??? | svchost | Smart-Clip | 1 | 06-09-2009 10:28 |
help how to remove unlock code w220 | chitawira | Smart-Clip | 0 | 07-17-2007 13:18 |
any help how to record calls directly to pc | leonell | Sim Cloning and Scaning | 1 | 03-09-2006 17:26 |
how to record long time? | gsm2k2 | Siemens-Benq Flash Patching | 5 | 12-22-2004 13:42 |
how to make a backup of my x105 flash | KamiMark | Trident/AGERE Platform | 0 | 04-14-2004 00:51 |
