11-11-2015, 12:13 | #1 (permalink) |
No Life Poster Join Date: May 2014 Location: D.I.Khan [KPK] Age: 34
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | QMob S1 [AntiTheift Removal] QMobile S1 Updated to Lollipop forgotten AntiTheift Code been removed in couple of seconds, while others failed Last edited by EjazATF; 11-11-2015 at 12:18. |
The Following 6 Users Say Thank You to EjazATF For This Useful Post: |
11-12-2015, 15:46 | #2 (permalink) |
Member: 2192499 Status: Offline Sonork: Stopped using.. Thanks Meter: 1,763 | Code: Operation : Reset Privacy Lock [ v1.36 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 61 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4838473165050787A134917209 DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : e1G8 [eMMC] : FLASH_CID : 90014A4838473165050787A134917209 [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:25 Reconnect Power/Cable! |
The Following 5 Users Say Thank You to EjazATF For This Useful Post: |
