how to remove contect service center how to remove contect service center in samsung sgh b189 plz help sir and which cable use in it thanks in addvance |
i m using 1.41 module |
Rebuild ur phone remove back cover and battery u will find golden point's pinout's you can find in shell Wbr <<<Megatron>>> Sent From Mobile Device |
COM21 [VCP0] selected module v1.41 Device: Samsung-SCH-B139, B189 operation: SP-unlock Phone should be Switched ON ! connecting... Connecting, wait... error: can't activate test mode If phone can not be connected after several tries make this: 1. Insert original sim card in phone 2. Power-On phone 3. go to Menu, press 6 then * and type password 123456 4. go to "Port Map", HKF 5. select "UART1" error: operation failed Finished, time used: 26 sec |
it is useful to u Rebuild ur phone remove back cover and battery u will find golden point's pinout's connect rx,tx,and gnd battry must be full samsung rebuilder.exe download and use it may be use full to u |
Check UR Cable Connection Also Check Weather You Have Selected Proper Com Port Wbr <<<Megatron>>> |
tanks sir u r support set has been unlocked sucses fully |
