Old 11-22-2015, 14:44   #1 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
HOW to remove gionee M5 FRP LOCK ?
HOW to remove gionee M5 FRP LOCK WITH INFINITY
Old 11-22-2015, 14:50   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
FULL FACTOY RESET option and "Fomat FS / Reset Settings" button.
Old 11-22-2015, 15:05   #3 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
mr.JayDi
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6735
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6735_S00
Processing BROM stage
SecCfgVal : 0x00000000
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
NAND_ID : 00000000000000000000000000000000
eMMC_ID : 520001154D313238464600424F0001E0
DA Stat : v4.2 on BBID : 0x93
DRAM not initialized , configure DRAM Settings
DRAM EmiReq Ok , 0x00BC
Error : DA init Failed! Error code : 0x5
LErr : EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:19
Reconnect Power/Cable!
I HAVE this error when i make info
Old 11-22-2015, 15:09   #4 (permalink)
JayDi's Avatar
Member: 462970
Don't press any key, just cable in phone.
Old 11-22-2015, 15:18   #5 (permalink)
atou's Avatar
Member: 1388609
Sonork: atou
Thanks Meter: 156
Operation : Format FileSystem [ v1.37 ]
Wait for phone...
Phone found! [ 42 ]
Sync...
Boot Info :
BB_CPU_ID : 6735
BB_CPU_HW : CA00
BB_CPU_SW : 8A00
BB_CPU_SB : 0000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0015 , OEM : 0100
[eMMC] : FLASH_INF : [SAMSUNG] , BM128
[eMMC] : FLASH_CID : 150100523832314D42004646E001724F
[eMMC] : FLASH_EXT : 0x00400000 , 0x00400000 , 0x00400000
[eMMC] : FLASH_LEN : 0x00000003A3E00000
[eMMC] : FLASH_UCP : 14910 MiB
INT RAM : 0x00020000
EXT RAM : 0x80000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear Google Reset Protection
Clear Ok!
Clear DIN
Clear Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:29
succes frp lock unlock
thx
The Following User Says Thank You to atou For This Useful Post:
Old 06-23-2016, 09:49   #6 (permalink)
abishekkumar's Avatar
Member: 1761355
Sonork: 0818211
Thanks Meter: 105
Old 06-23-2016, 10:26   #7 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Originally Posted by abishekkumar View Post
HelloBrother abishekkumar,
This is INFINITYBOX SECTION
THE POWER &PROFESSIONALS BOX Or CM2.
Kindly Dont post here such Rubxxsh.
Wbr
Page generated in 0.90628 seconds with 8 queries
