10-01-2015, 15:00 | #1 (permalink) |
Crazy Poster Join Date: Mar 2011
Member: 1539229 Status: Offline Thanks Meter: 7 | how to remove infinix zero x509 privacy protection i have infinix x509 with privacy protection..... already try reset privacy lock but phone stil ask code, try full factory reset phone still ask code... help please............... Thanks Wait for phone... Phone found! [ 26 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6753 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6753_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D423133BD5B01424F28A1F4 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMB13 [eMMC] : FLASH_CID : 150100523331424D42015BBDF4A1124F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Infinix ProdName : Infinix_X509 ProdModel : Infinix X509 Device : Infinix_X509 AndroidVer: 5.1 MTKxCPU : MT6735 MTKxPRJ : ALPS.L1.MP3.V2_RGK6735.35GU.L1_P1 MODEM : BaseBand : MT6735_S00_J5808_C1_LWG_MP_V0_1_6_S150801_1_lwg_n |
10-01-2015, 15:07 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Just make "Reset Privacy" lock option. After, just for make sure - "Full Factory Reset". Post both logs after. |
10-01-2015, 15:16 | #3 (permalink) |
Member: 1539229 Status: Offline Thanks Meter: 7 | try reset privacy.... still lock Operation : Reset Privacy Lock [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6753 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6753_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D423133BD5B01424F28A1F4 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMB13 [eMMC] : FLASH_CID : 150100523331424D42015BBDF4A1124F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Checking data ... Privacy Lock reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! ============================== try full factory and here's log Operation : Format FileSystem [ v1.32 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 26 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6753 BB_CPU_HW : CA00 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6753_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 520001154D423133BD5B01424F28A1F4 DA Stat : v4.2 on BBID : 0x93 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : BMB13 [eMMC] : FLASH_CID : 150100523331424D42015BBDF4A1124F [eMMC] : FLASH_EXT : 00400000/00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 INT RAM : 0x00020000 EXT RAM : 0xC0000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear Google Reset Protecton Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! phone stil ask privacy code |
10-01-2015, 15:18 | #4 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Try selected "RESET USER LOCKS" and post results.... |
The Following User Says Thank You to maomatrix For This Useful Post: |
10-01-2015, 15:31 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Better just read NV and make "debugLog". Other - SP : Make DebugLog It help me alot on checking problem. Reset UserLocks normally not touch sensetive data, it strange. |
10-01-2015, 15:56 | #7 (permalink) |
Member: 1539229 Status: Offline Thanks Meter: 7 | already try reset factory and reset privacy many times almost 5time but still lock, after reset user lock phone stuck on logo, after power on again, yessss unlock.. thanks for support, this debug log |
10-01-2015, 17:37 | #8 (permalink) |
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | YES Mr. JaiDy If it works, tested 1000000%, when it does not delete the code in the normal way, always select RESET USER LOCK and wualaaaa... the phone looks perfect |
