03-23-2009, 17:45 | #1 (permalink) |
No Life Poster Join Date: May 2006 Location: HEAVEN
Member: 285345 Status: Offline Thanks Meter: 324 | how to remove network lock but still is same. I also format it also change imei. but still same |
03-23-2009, 17:46 | #2 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | COM48 selected module v2.77 Action: unlock unlock method: smart fast Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On chip: 0031:A7C1:2CE6 status: FF detected CPU: MT6226MA Connecting at 19200, wait... Release Power button now ! Phone detected, wait... Hardware: MT6226M,E02 Date: 2005.04.12 Version: 1.0 Version: DS606_332B43_SW_MyWay_V4.71 Version: DS606_6226_MBPCB_V1.0 detecting structure #2... 0 done 44 byte(s) read imei: 35208565456454 connection Ok detecting structure #1... 0 done 148 byte(s) read reading data... building new data... writing data... done Finished, time used: 22 sec Remove/Install battery now ! |
03-23-2009, 17:53 | #4 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | When I read general information.here r logs. Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226M, E0 Hardware version: DS606_6226_MBPCB_V1.0 Software version: DS606_332B43_SW_MyWa Software date: 2005.04.12 Barcode: MT012345678901234567 imei: 352085654564546 Finished, time used: 36 sec Power off phone now ! |
03-23-2009, 18:17 | #5 (permalink) |
Member: 285345 Status: Offline Thanks Meter: 324 | When I format it,during formatting it show all locks r off. but still asking for network lock code. Phone lock: Off Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1122 |
03-23-2009, 19:17 | #6 (permalink) |
No Life Poster Join Date: Dec 2008 Location: India Age: 35
Member: 923397 Status: Offline Sonork: 100.1584169 Thanks Meter: 451 | ok bhai jaan par aap konsa box use kar rahe hai agar aap infinity use kar rahe hai to aap us par format kare or uska sara process yahan par post kare ok |
03-24-2009, 07:41 | #9 (permalink) | |
Member: 285345 Status: Offline Thanks Meter: 324 | Quote:
COM11 selected module v2.77 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6219:8B02:8B01]... CPU: MT6219 high speed boot On detected CPU: MT6226MA chip: 0031:A7C1:2CE6 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #02 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #03 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 460800 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb detecting chip #01 in region #00... flash: 2088C4FFFFFFFF:2088C400000000 flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.19FFA351.[DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_71.BIN_611D8539].rpl identification#1 detection finished device-id: 19FFA351 identification#1 protocol ver: 05 ver. sw 1: DNET26_06A_PCB01_GPRS_MT6226_S01.DS606_332B43_SW_M YWAY_V4_71.BIN ver. sw 2: DS606_332B43_SW_MyWay_V4.71, C67AE29E ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . detect device identification#2 finished detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: 2088C4FFFFFFFF:2088C400000000 checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... .................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ............................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 detecting ffs/eeprom structure pass 2... .................... detect standard fat location pass #1... .................................................. ...... detect extended fat location pass #1... ............................................. detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok element #2 Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\s ystem_log_19FFA351_DNET26_06A_PCB01_GPRS_MT6226_S0 1.DS606_332B43_SW_MYWAY_V4_71.BIN_611D8539_2009032 4-114054.B0X.bin Finished, time used: 62 sec Remove/Install battery now ! | |
03-24-2009, 19:10 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! make full backup (read full flash operation), save it to safe place for emergency restore. download from support file named [bin] flashfiles/Orange/Tokyo/Orange_Tokyo_DNET26_06A_PCB01_GPRS_MT6226_S01.DS60 6_332B43_SW_MYWAY_V4_71_2007-11-29_En_Fr.B0M.bin flash to your phone and check result |
help to remove network lock in vk4000 | hans salim | Infinity-Box | 1 | 05-04-2008 09:32 |
Help I need to remove Network lock on a LG U8138 with HWK UFS-3 | mphillips11 | UFS2 + UFS3-Tornadoflasher | 0 | 12-05-2005 20:35 |
C25/28 V61 how to remove user lock? | maks | x1x to x45/x50 | 25 | 08-23-2001 11:55 |
How to remove the Lock code from this phone ? | gsm_trade | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-04-1999 15:34 |
how to remove SP lock on Ericsson s868 | Tim | Old Ericsson Phones & Sony Phones | 3 | 07-15-1999 22:33 |
