04-02-2008, 11:03 | #1 (permalink) |
Registered User Join Date: Mar 2006
Member: 247893 Status: Offline Thanks Meter: 82 | How to repair chinesse miracle restarting problem restart as soon as its searching for network. COM2 [VCP0] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot... Press and HOLD Power button now ! error: boot initialization step-2 failed: 00 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031:1272:5AB1 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 115200 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:29EA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 290000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.B4C2F84A.[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN_A36E 3A79].rpl identification#1 detection finished device-id: B4C2F84A identification#1 protocol ver: 04 ver. sw1: E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN ver. sw2: E553_K4SMCHARAB.01.1, 86C5915C ffs offset/size: 00800000/001FF000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00800000 flash: EC257E25082501:29EA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 Detected eeprom/ffs address is non-standard: 00E00000 Posible reasons: 1. eeprom is Ok but address is non-standard 2. eeprom damaged and can't be detected 3. eeprom is Ok but detected incorrectly (f.e. unknown eeprom structure) If you are not sure that detected address is correct: 1. press "NO" (and select standard address or terminate current operation) 2. make flash backup for emergency case 3. repeat required operation Are you sure that detected eeprom address is correct ? autodetected eeprom/ffs address[00E00000] confirmed by user detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_1.BIN]_20080402-093438.B0E.bin flash: EC257E25082501:29EA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished security area#1 calculation... done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _B4C2F84A_E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_ 1.BIN_A36E3A79_20080402-093450.B0X.bin Area: Firmware flash: EC257E25082501:29EA0000000000 Write: Firmware detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Write Done Finalization... Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _B4C2F84A_E553_K4SMCHARAB_E553_GPRS_MT6226_S01.01_ 1.BIN_A36E3A79_20080402-093555.B0X.bin Finished, time used: 432 sec Remove/Install battery now ! is there any solution for this? |
04-02-2008, 11:14 | #2 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Algeria
Member: 483440 Status: Offline Thanks Meter: 191 | Look at help file 1. make full flash backup for emergency case (use 921000 speed for fast operation). It's very important step ! 2. select "safe" format method 3. make "format ffs" 4. remove/install battery 5. press and hold phone "Power" button during 30-40 sec to make phone Powered-On if phone Ok go to step-6 if phone still in reboot/restart/freez state: select "complete" format method and go to step 3 if phone still in reboot/restart/freez state: try to use other SIM card, some phones works not good with some SIM cards if phone can't Power-On: restore original flash backup if you don't have original backup: write different firmware files with firmware version similar to original 6. restore original imei 7. if phone has touchscreen LCD make calibration: click to LCD corners one by one if still no luck: check phone hardware (f.e. reball CPU and/or Flash chip) |
04-02-2008, 11:32 | #3 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i can advice to call 112 without sim card inserted. if it is resterting even without card- there is hardware damage of RF part (like amplifier or else) |
How to repair Chinese phones with problems like "not power on/reboot/restart.. etc" | GSMtricks | Chinese Cocktail | 37 | 11-15-2012 05:23 |
How to repair Chinese phones with problems like "not power on/reboot/restart.. etc | GSMtricks | PadFinder box | 3 | 09-03-2008 08:10 |
How to repair Chinese phones with problems like "not power on/reboot/restart.. etc | GSMtricks | PadFinder box | 1 | 07-24-2008 13:50 |
How to repair chinesse miracle restarting problem | francogsm | Infinity-Box | 3 | 04-02-2008 20:55 |
