01-31-2017, 15:30 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | How to Repair Huawei QC Mobile / write dload firmware via CM2QLM in less words, take this post as example in case you not found same build or down build or any upgrade related errors. Huawei Ascend G6 with full of viruses and annoying app stop notification Phone Info; Code: Model = G6-U10 Build = V100R001C900B135 Custom = CUSTC428D002 Code: Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07486DFE ID_BLOCK_I : 008140E1 ID_BLOCK_L : 8B7D17EF4ED4C1CCBB90606DAAF10149 ID_BLOCK_L : 0372DC6F60F35BE8EDC88D7A48A7B19A Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : G6-U10 ProdModel : HUAWEI G6-U10 Device : hwG6-U10 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 Done! Elapsed: 00:00:19 Reconnect Power/Cable! Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07486DFE ID_BLOCK_I : 008140E1 ID_BLOCK_L : 8B7D17EF4ED4C1CCBB90606DAAF10149 ID_BLOCK_L : 0372DC6F60F35BE8EDC88D7A48A7B19A Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : G6-U10 ProdModel : HUAWEI G6-U10 Device : hwG6-U10 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__HUAWEI_G6-U10__hwG6-U10__G6-U10 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : oemdata.bin [Read Ok] : NON-HLOS.bin [Read Ok] : fs_gc.img [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cust.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1197 MiB Done! Elapsed: 00:03:22 Reconnect Power/Cable! In this case I am using. dload firmware Info; Code: Model = G6-U10 Build = V100R001C900B117 Custom = CUSTC433D001 6: in read firmware folder ( which you save in step 2 ) replace system.img file with extracted from update.app 7: write firmware back with CM2QLM 8: done note (1): its good if you find same build and able to write via sd card note (2): find posible near build if cant find same one. note (3): always keep safe backup / read firmwere data before replacing system.img or any part of firmware. Note (Last) = I did not make this post to take blame of any damage so at least one thing be your's..??? RISK CM2 |
The Following 13 Users Say Thank You to Nasir Mobiles For This Useful Post: |
02-01-2017, 09:46 | #2 (permalink) | |
Member: 355782 Status: Offline Thanks Meter: 1,265 | forget to add write firmware log; here Quote:
The Following 5 Users Say Thank You to Nasir Mobiles For This Useful Post: |
02-19-2017, 13:22 | #4 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | I can upload but without system image. original image was bad so useless. and new extracted system img too large and I have slow up link cant upload right now. if you have dload firmware you can extract system image from. |
02-19-2017, 14:54 | #6 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | File Name: MSM8610__HUAWEI__Huawei__ANDR_v4.3__HUAWEI_G6-U10__hwG6-U10__G6-U10 File Size: 70.1 MB Link: https://mega.nz/#!k5MhgAyb!SjzGMeJXT...0LbIJasSISSLtU |
The Following User Says Thank You to Nasir Mobiles For This Useful Post: |
02-22-2017, 04:55 | #9 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Paranaque
Member: 2519102 Status: Offline Sonork: [email protected] Thanks Meter: 93 | bro did video guide for dload write firmware via CM2QLM for we understand of how to use bro??thanks if you would do a video cost us novice cm2 |
02-22-2017, 05:05 | #10 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | 1. Extract FW from app. 2. Use MemoryTool feature to repair device. 3. Read working FW from device after repair. 4. ???????? 5. Profit! |
The Following 10 Users Say Thank You to JayDi For This Useful Post: |
02-23-2017, 09:08 | #12 (permalink) |
Member: 355782 Status: Offline Thanks Meter: 1,265 | a fully working , tested firmware uploaded to support area. download from support area. Code: Operation : Read Flash [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 07486DFE ID_BLOCK_I : 008140E1 ID_BLOCK_L : 8B7D17EF4ED4C1CCBB90606DAAF10149 ID_BLOCK_L : 0372DC6F60F35BE8EDC88D7A48A7B19A Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : G6-U10 ProdModel : HUAWEI G6-U10 Device : hwG6-U10 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__HUAWEI_G6-U10__hwG6-U10__G6-U10 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : oemdata.bin [Read Ok] : NON-HLOS.bin [Read Ok] : fs_gc.img [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cust.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1178 MiB Done! Elapsed: 00:03:22 Reconnect Power/Cable! MSM8610__HUAWEI__Huawei__ANDR_v4.3__HUAWEI_G6-U10__hwG6-U10__G6-U10.7z |
The Following 6 Users Say Thank You to Nasir Mobiles For This Useful Post: |
02-23-2017, 12:40 | #15 (permalink) | |
Freak Poster Join Date: Jan 2013 Location: layyah pakistan Age: 31
Member: 1869772 Status: Offline Sonork: 100.1615569 Thanks Meter: 10 | Quote:
