03-11-2016, 15:54 | #1 (permalink) |
No Life Poster Join Date: Apr 2009 Location: The Great India
Member: 1004995 Status: Offline Thanks Meter: 230 | Aqua y2 pro unable to flash. Elapsed: 00:00:21 Reconnect Power/Cable! Scatter Load Ok , BaseBand : MT6572 , Project : wt97057 , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Operation : Flash [ v1.42 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447453001DC0B23F35231 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:14 Reconnect Power/Cable! How can be it solved ? Regds Narendra Singh |
