Old 09-29-2016, 16:17   #1 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
how to reset frp huawai TAG-L21
THANX
Old 09-29-2016, 17:50   #2 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Hello.
Use LATEST CM2MTK.
Make connect 2-3 times. It will show "SECURITY_BOOT_ERROR".
After it became dead. Now it able to boot.
Make FRP reset ( separate option in FMT settings ) and make WIPE.
Make FW read.
Do "Init Preloader" , select preloader from FW, which CM2 read.
Disconnect phone. Power on. Enjoy.
The Following 7 Users Say Thank You to JayDi For This Useful Post:
Old 09-30-2016, 09:30   #3 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
Card found : S/N : 7DBA7787 , v0132
Chinese Miracle II [MTK module] v 1.55
Operation : Check / Read Info [ v1.55 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:11
Reconnect Power/Cable!
Operation : Format FileSystem [ v1.55 ]
Wait for phone...
Device boot not done
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:41
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:41
Wait for phone...
Check Drivers
Try again
Boot Error!
Operation Failed
Elapsed: 00:00:27
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:18
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:54
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:43
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:15
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:58
The Following User Says Thank You to rai14 For This Useful Post:
Old 09-30-2016, 10:35   #4 (permalink)
JayDi's Avatar
Member: 462970
You can try 100-200-over9000 times, but until you not press BOTH volume buttons at every connect try - that will not work.
The Following User Says Thank You to JayDi For This Useful Post:
Old 10-01-2016, 08:10   #5 (permalink)
Member: 1562854
Sonork: 1245
Thanks Meter: 259
Probleme solved thanx
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019065324741C31E0705871248B0
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A484147326505071EC3B048C287
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0x05EC4395634453BCBEAABA5D8E550D52
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Clear FRP ( Google Reset Protection )
Clear Ok!
Done!
Elapsed: 00:00:37
User selected Preloader file : preloader_L21_Infinity_v1.01.bin
Operation : Init Preloader [ v1.55 ]
Supported HW by Preloader :
FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX]
FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX]
FlashID [2] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG]
FlashID [3] CID : 13014E52314A39364E , Name : R1J96N , Vendor : 13 , [NOT_IN_BASE]
FlashID [4] CID : 110100303136473332 , Name : 016G32 , Vendor : 11 , [TOSHIBA]
Wait for phone...
Phone found! [ 6 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
SecCfg Passed , 179A
BL : Storage supported by BootLoader!
Sending BootLoader ...
Preloader Sent , Init passed
PartTable Init Ok , Count : 19
All Done
Done!
Elapsed: 00:00:13
The Following 3 Users Say Thank You to rai14 For This Useful Post:
Old 11-24-2017, 19:17   #6 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 157
Originally Posted by JayDi View Post
Hello.
Use LATEST CM2MTK.
Make FW read.
Thank you thank you thank you very very very muuuuch...
Old 11-24-2017, 20:09   #7 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
This tuto or tweak its without update mtk module but if new mtk module its released !? It will be a revolution in World of mtk software développement
Old 11-24-2017, 20:14   #8 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 2,102
Hello.
Use LATEST CM2MTK.
Make FW read.
Make firmware read befor or After it will become dead ?
Old 11-25-2017, 05:05   #9 (permalink)
Arslanmayo's Avatar
Member: 2478233
Thanks Meter: 596
first do firmware read then do any operation you like
Old 09-21-2018, 15:00   #10 (permalink)
Member: 579725
Sonork: 100.1675677
Thanks Meter: 96
Preloader Init Failed! HW error or incompatible image? Try make "Flash Erase" first!
??? error when click init preloader
Page generated in 0.21317 seconds with 8 queries
