Old 05-07-2008, 20:49   #1 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
How to reset security code in Vodafone 226 - Sagem My220v
Hi.
I unlock a Vodafone 226 ( Sagem My220v ), but now I need security code.
How to reset
Thanks in advance.
Old 05-08-2008, 07:11   #2 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Try to flash it !
Good luck !
Old 05-08-2008, 07:51   #3 (permalink)
Tinotenda's Avatar
Member: 46546
Sonork: 100.1577435
Thanks Meter: 85
Originally Posted by usernome View Post
Try to flash it !
Good luck !
flash it with what????????????????
Old 05-08-2008, 11:32   #4 (permalink)
usernome's Avatar
Member: 19723
Thanks Meter: 359
Ooopppsss ! Infinity is not able to flash . Sorry ! I use Furious .
Old 05-08-2008, 12:29   #5 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
Ok, thanks for try.
Any other solution using Infinity Box?
Infinity Box Team can help-me?
Thanks in advance.
Old 05-08-2008, 12:32   #6 (permalink)
gsmsalik's Avatar
Member: 207447
Thanks Meter: 48
not solution in infinity white next update for solve the problems or use furious box
Old 05-08-2008, 13:20   #7 (permalink)
kimo59's Avatar
Member: 183437
Thanks Meter: 97
problem solved 1 month ago by an infinity user (thx man), infinity was the first tu remove code poste on sagem and vodaphone
C:\Program Files\InfinityBox\Pana01
READ EPROM
SELECT RESET EPROM
WRITE EPROM COMPLETE
tested 100000000000000000%%%%
Old 05-08-2008, 14:07   #8 (permalink)
Member: 175183
Sonork: 0
Thanks Meter: 120
READ EPROM
SELECT RESET EPROM
Thanks for reply.
I will try this solution.
Old 09-07-2011, 10:08   #9 (permalink)
Member: 1467129
COM4 [VCP0] selected
module v1.78
Device: Sagem-my220v
Checking data, wait...
Action: "sp-unlock"
unlock method-1
Boot ...
e-gold: 820010
loading...
middle part...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:011A
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
sw version: 8 EBI_IO_101207_1704 EBI_IO 101207_1704 Thhmm Dddmmmyyyy 0123
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: c:\InfinityBox\Pana01\Sagem-my220v_eeprom-static_20110907-100005.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: c:\InfinityBox\Pana01\Sagem-my220v_eeprom-security_20110907-100006.B1E.bin
reading eeprom-complete...
file saved: c:\InfinityBox\Pana01\Sagem-my220v_eeprom-complete_20110907-100011.B1E.bin
reading additional data...
file saved: c:\InfinityBox\Pana01\Sagem-my220v_lock-area_20110907-100037.B1E.bin
backup critical area Done
Check memory ...
lock found
lock type #1 found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 1 min 51 sec
Remove/Install battery now !
How to reset security code in Vodafone 226 - Sagem My220v gsm_unlock2 SAGEM JTAG UNLOCKER 2 05-08-2008 14:05
How To Reset Security Code In C333 U.s ????????? juanaldo Motorola P2k 1 08-05-2003 00:11
How to reset security code in C350?? doberman Motorola P2k 1 07-23-2003 19:31
HOW TO RESET SECURITY CODE IN NOKIA 6210 ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-26-2001 05:33
HOW TO RESET SECURITY CODE IN NOKIA 6210 ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 05-01-2001 17:48
Page generated in 0.27162 seconds with 9 queries
