03-02-2015, 23:01 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | how to solve this issue ? mt6572 S5 clone g900f Code: Chinese Miracle II [MTK module] v 1.14 Operation : Check / Read Info [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 179 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 000100BC009000550056000100BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0094 , [Spansion] KEM51200_NADGSBXM2C32 [NAND] : FLASH_DIE : 0001 00BC 0090 0055 0056 0001 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! NAND : Detecting structure now... Please, wait. NAND : Structure detect done [31] [AP] : Initial info read Ok! Done! Elapsed: 00:00:57 Reconnect Power/Cable! Code: Operation : Format FileSystem [ v1.14 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 179 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8C00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending NAND_ID : 000100BC009000550056000100BC0000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DA Sent. Configure setting now ... DA started successuflly NAND FlashIC initialized [NAND] : FLASH_VEN : 0x0094 , [Spansion] KEM51200_NADGSBXM2C32 [NAND] : FLASH_DIE : 0001 00BC 0090 0055 0056 0001 00BC [NAND] : FLASH_LEN : 0x20000000 INT RAM : 0x00020000 EXT RAM : 0x10000000 BOOT TYPE : NAND_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Error read initial info , blank flash or wrong settings? Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! |
The Following User Says Thank You to yurais For This Useful Post: |
03-02-2015, 23:04 | #2 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | i found this file searching for a flash file, it has no extension, so I dont know if it is possible to write, and which tool was it designed for ? Download Galaxy S5 Mt6572 Sm G900f YFg-WNYYba - NextWap.Net |
03-03-2015, 05:54 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Better not try write unknown things. I see in logs wrong operations : Read Info, Format. In this way it will work. |
03-03-2015, 14:53 | #5 (permalink) |
Member: 220595 Status: Offline Thanks Meter: 355 | Well, nobody has a good file ? and there is no anything wrong on my procedure, I read info and then try to format. I also tried or NAND INIT options. |
