02-07-2010, 15:37 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: indonesia Age: 40
Member: 447517 Status: Offline Thanks Meter: 22 | how to solve this problem.. COM46 [VCP0] selected module v3.08 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: repair security area enhanced security fix enabled ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6226:8A02:8A01]... CPU: MT6226 high speed boot Off chip: 0031:5FE6:E72E status: FF high speed boot Off boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #02 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #03 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 number of flash chip/regions detected: 04/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... interesting cpu type found Initialize bootcode Done ====> Check firmware integrity ... device parameters detection in progress... detecting chip #00 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 detecting chip #01 in region #00... flash: 98004900000002:2AEA0000000000 flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb otp offset: 00FF0000 it's time to stop: 2A0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: 2nd [enhanced] generation TCL-ID is absent startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.D88821FE.[TYM702038_842_PCB01_GPRS_MT6226_S01.702038_842_V44 20.BIN_0C9A2B17].rpl rom info detection finished ==================== New firmware detected (v.3.08, database date: unknown): TYM702038_842_PCB01_GPRS_MT6226_S01.702038_842_V44 20.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== device-id: D88821FE rom info ver: 04 sw version: TYM702038_842_PCB01_GPRS_MT6226_S01.702038_842_V44 20.BIN project-id: 702038_842_V4420, 172B9A0C code offset: 00000000 ffs offset/size [01]: 00E00000/00200000 rom info structure: 2nd [enhanced] generation TCL-ID is absent detecting startup code area #2... .................................................. .................................................. .................................................. .................................................. .................................................. ...... startup code area #2 is absent startup code area #1 check... startup code area #1 fixed sec info (fast) detection... searching sec info#1... . search sec info#1 finished error: incorrect ffs address range file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_ system_log_D88821FE_0C9A2B17_20100207-212450.B0X.bin Finished, time used: 1 min 39 sec Remove/Install battery now ! 1. ffs complete mode 2. repair security but still same.. please, how to solve this problem? |
I how to solve this problem | Saulcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-30-2010 10:02 |
How to solve this problem ? [Problem] | amar181 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 9 | 11-25-2009 15:00 |
Your security card going to expired soon.How to solved this problem | hajji1 | Cyclonebox | 1 | 11-05-2009 17:05 |
System Failure - How to solve this problem | miq | Samsung Hardware Repair | 17 | 01-31-2006 13:16 |
how to solve this problem | Jazzy | x1x to x45/x50 | 15 | 07-29-2001 20:18 |
