Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2000 Location: North / East Uk .... Pussy Hunter . Age: 26
Member: 2461 Status: Offline Thanks: 11
| How to Unlock the Alcatel OT-S621 HAVE SOLDERED THE RJ45 CABLE TO THE PINS ON THE FONE , BUT THE SWARE Just says to flash the fone ? Is there any procedure etc to do this |
| | #2 (permalink) |
| Flashed the fones firmware with the virgin 1 from support area . but still locked tho ![]() COM11 [VCP0] selected module v2.62 Device: Alcatel-S621X Checking data, wait... advanced flash detection enabled Action: write NOR flash "smart write" active write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs Boot ... Press and HOLD Power button now ! baud autodetection active 19200 autodetect Connecting, wait... Initializing [6225:8A03:8A00]... CPU: MT6225 chip: 0001:A103:A004 boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: 01227E22422200:18E59F00000000 flash: Amd AMD/Fujitsu std [D 0004x008000 00FEx020000 0004x008000] 32Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area (code #1) is Ok security area (code #1) backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.81671 E20.[JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN_647456AF].rpl identification#1 detection finished device-id: 81671E20 identification#1 protocol ver: 05 ver. sw 1: JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_06B_W07_28_SP 1_V34.BIN ver. sw 2: MAUI.06B.W07.28.SP1.V34, 50A98B9B ffs offset/size: 01020000/00FE0000 detect device identification#2... detection phase #1... detect device identification#2 finished sim-lock status: enabled Check firmware integrity Done Check firmware content ... Check firmware content Done Backup required data ... original imei: 35199002100703 Backup required data Done Patch required data ... Patch required data Done Special operation ... Special operation Done Write ... security area (code #1) calculation... done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_81671E20_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_647456AF_20090129-105057.B0X.bin Area: Firmware flash: 01227E22422200:18E59F00000000 Write: Firmware detect device identification#2... detection phase #1... detect device identification#2 finished security area (code #3, part #2) calculation... customization: CD54CW08 done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #2) security area (code #3, part #2) calculation done security area (code #3, part #1) calculation... ..................security area (code #3, part #1) detecting size... security area (code #3, part #1) detecting parameters... security area (code #3, part #1) encoding... done flash: 01227E22422200:18E59F00000000 flash: 01227E22422200:18E59F00000000 Write: security area (code #3, part #1) security area (code #3, part #1) calculation done Write Done Finalization ... Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\system_l og_81671E20_JRD25_06B_PCB01_GPRS_MT6225_S00.MAUI_0 6B_W07_28_SP1_V34.BIN_647456AF_20090129-112005.B0X.bin Finished, time used: 1786 sec Remove/Install battery now ! |
| | #3 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006
Member: 391664 Status: Offline Sonork: 100.1580390 Thanks: 228
| S621X-2AALAP1_XD54BM02_JRD25_06B_PCB01_GPRS_MT6225_S00[1].MAUI_06B_W07_28_SP1_V34_2008-07-22_En_Fr_Tr_Ar_simfree.B0M use this file BR ![]() UMER |
| The Following User Says Thank You to maplegsm For This Useful Post: |
| | #6 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Nov 2001 Location: Zagreb, Croatia
Member: 7558 Status: Offline Sonork: 100.94170 Thanks: 10
| HI I have problems with some phones because after flashing there is no croation lang inside. support need croation lang ... I flash with all flashes from support but only 1 is simfree and dont have croation lang.. Best Regards G$Msolution |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2004 Location: http://speed.g-zona.hr Age: 37
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks: 50
| Here you go, pinout is in the attachment. |
| The Following 2 Users Say Thank You to g-zona For This Useful Post: |
| | #11 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: ![]() Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to unlock a Alcatel OT-708 | wrioram | Phone Unlocking Codes & Maps | 279 | 07-05-2010 10:13 |
| Help to unlock my Alcatel OT 708 Mobile | youkp2 | Phone Unlocking Codes & Maps | 1 | 12-18-2009 01:40 |
| How to use Cable ALcatel ot-s520 | Qaisar Mahmood | Infinity-Box | 1 | 09-17-2008 13:07 |
| How do Unlock Rare Alcatel OT 556 GSM cell phone? | oraraji | Alcatel TCL Hardware Repair Section | 4 | 06-20-2006 11:17 |
| How to unlock the EEPROM of the GD87?? | FLH2002 | Panasonic | 15 | 02-12-2005 18:36 |
