Old 09-11-2007, 16:48   #1 (permalink)
Member: 175640
Thanks Meter: 7
how to unlock c139 indian airtel mobile
COM4 [VCP0] selected
Action: unlock
Device: C139,C140
Checking data, wait...
Connect...
Press and HOLD Power button...
connection mode: 00
error: boot failure[04]: general communication fault.
Release Power button !
Connect Fail
Finished, time used: 9 sec
Remove/Install battery now !
Old 11-30-2007, 20:04   #2 (permalink)
aikonmani's Avatar
Member: 304090
Thanks Meter: 210
use com cable.
do connection "method version 4" in setting tab.
for safety "read flash"
After that unlock.
Look here>>>>
COM1 [Serial0] selected
Action: unlock
Device: C139,C140
Connect...
connection mode: 02
Connect Done
Boot...
Boot Done
Set Baud...
115200
Set Baud Done
Check Flash-1...
SW version: 1.3.29
HW version: _E88
LP ver: LPH_C139_ASIA2_Z1C
Flex ver: FFH_C139_67_Z1C
imei otp: 357251001483195
Check Flash-1 Done
Check Flash-2...
reading ...
file saved: backup_eeprom_calibration_357251001483195_20071201-002443.31E.bin
imei eeprom: 357251001483195
extra method pass-1...
reading ...
extra method pass-2...
Check Flash-2 Done
Write...
Write Done
Finished, time used: 61 sec
Old 12-01-2007, 07:18   #3 (permalink)
Chandreshswami's Avatar
Member: 370998
Sonork: 100.1582579
Thanks Meter: 219
you can also use motorola foxlink cable available with c261
if you have problem with RJ45 cable
Old 12-01-2007, 07:26   #4 (permalink)
IkaMazini's Avatar
Member: 162473
Sonork: Not have
Thanks Meter: 592
uncheck RTS Line ON/OFF + DTR Line ON/OFF
and try again unlock
post result
how to unlock blackberry 8900 Airtel... anil2006 BlackBerry (RIM) 9 08-16-2009 22:06
how to unlock c139 doctorhu Smart-Clip 4 02-01-2007 06:49
How to unlock c139 imei star 000 Nishant jain Motorola Hardware Repair 0 11-20-2006 07:00
How to unlock C139 tlawryn Motorola P2k 9 09-08-2006 09:04
how to unlock c139 and v180 with sc? mmanduri Smart-Clip 3 07-16-2006 21:24
Page generated in 0.14468 seconds with 10 queries
