Old 01-23-2008, 10:49   #1 (permalink)
khaleefa's Avatar
Member: 520336
Thanks Meter: 50
how to unlock FLY slt100
enter NP code???????????
COM1 [Serial0] selected
Action: read codes
unlock method: read codes
Model: Fly SLT100
Checking data, wait...
19200
Initializing[6228:8A02:8A02]...
CPU: MT6228
chip: 0031:0000:0101
Connecting, wait...
Release Power button now !
Phone detected, wait...
Hardware: MT6228,E02
Date: 2004.07.02
Version: 1.0
Version: MAUI.06A.W06.36.MP.V36
Version: EZIO28_06A_HW
42 byte(s) read
imei: 13579024681122
connection Ok
145 byte(s) read
reading data#2...
reading data#3...
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 0000
Finished, time used: 21 sec
Remove/Install battery now !
after this same enter NP code
The Following User Says Thank You to khaleefa For This Useful Post:
Old 01-23-2008, 13:58   #2 (permalink)
Member: 20069
Thanks Meter: 128
hello,
use search maybe this can help after reading some posts by InfinitySupport.
GoodLuck.
Old 01-23-2008, 14:17   #3 (permalink)
Member: 20069
Thanks Meter: 128
hello again,
flash ur phone with this ver. n for sure everything will ok with ur fone.
Fly-SLT100_Hummer-HT1_SLT100_HMERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W 06_36_MP_V36_M3.00R_2007-07-26_En_Ru_Ua
Good Luck.
Infinity uSeR
Old 01-23-2008, 18:12   #4 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,397
@khaleefa
How about to read thread near yours ?
http:///vbb/showthread.php?t=469930
One more advice: check support area for unlock instruction !
Old 01-24-2008, 12:45   #5 (permalink)
khaleefa's Avatar
Member: 520336
Thanks Meter: 50
Originally Posted by InfinitySupport View Post
@khaleefa
after flash working fine than******************x
Old 02-11-2008, 22:05   #6 (permalink)
Stylo_GSM's Avatar
Member: 177235
Sonork: 111568
Thanks Meter: 132
Hi,
I flashed th ephone to the file
And phone is still locked, I repeated unlock proceadure and still locked
Old 02-12-2008, 17:00   #7 (permalink)
Member: 130995
@Stylo_GSM
There is a manual in support area (Infinity-Box-How_to_unlock_Fly-SLT100.txt) but especially for you here is text from that manual to avoid... (I hope you can replace ... with correct words by yourself).
How to unlock Fly-SLT100:
1. make eeprom (or full flash) backup for emergencey case
2. make "read codes" or "smart safe" unlock procedure
3. if phone still locked flash phone with the next firmware files (depends on phone hardware type):
Fly-SLT100_SLT100_HMERID_PCB04_GPRS_MT6228_S02.MAUI_06 A_W06_36_MP_V36_M3.01R_64m_En_Ru_Ua.B4M.bin
or
Fly-SLT100_Hummer-HT1_SLT100_HMERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W 06_36_MP_V36_M3.00R_2007-07-26_En_Ru_Ua.B4M.bin
4. Press and HOLD phone "Power" button long time (up to 40-50 sec) after flashing to make phone Powered-On.
Old 06-02-2010, 13:52   #8 (permalink)
faruk_gsm's Avatar
Member: 877161
Thanks Meter: 48
Successfully unlocked/repaired phones by Infinity-Box
Old 06-02-2010, 13:53   #9 (permalink)
faruk_gsm's Avatar
Member: 877161
Thanks Meter: 48
Successfully Unlocked fly SLT 100
FLESH YR PHONE --- Fly-SLT100_Hummer-HT1_SLT100_HMERID_PCB04_GPRS_MT6228_S02[1].MAUI_06A_W06_36_MP_V36_M3.00R_2007-07-26_En_Ru_Ua.B4M
COM5 [VCP0] selected
module v3.39
Device: Fly-SLT100
Action: write flash NAND
write: Firmware
Fly-SLT100_Hummer-HT1_SLT100_HMERID_PCB04_GPRS_MT6228_S02[1].MAUI_06A_W06_36_MP_V36_M3.00R_2007-07-26_En_Ru_Ua.B4M.bin
skip: Customization/Language Pack
skip: Customization
skip: Eeprom/ffs
firmware patch (sp-lock #1)...
not required
firmware patch (sp-lock #2)...
not required
nfi area detection...
external bootloader is not present
bootloader version: SLT100_HMERID_BOOTLOADER_V005_MT6228_MAUI_06A_W06_ 36_MP_V36.bin
nfi area detection finished: Ok
interface: BROM_DLL_v3.952.00
Connect...
Connecting...
Booting...
bootcode current/expected: 3.2/3.2
CPU: 6228:8A02:8A02
status: FF
bbchip bl ver: FE
NOR flash chip: not installed
NAND flash id[0017]: 00AD:007600AD0076 [HYNIX] HY27XS08121M
chip size: 64Mb
page/spare size: 0200/0010
pages per block: 0020
bits i/o: 08
address cycles: 04
internal RAM size: 00020000
external RAM: absent
done
Set baudrate (460800)...
done
ram test...
testing...
ram test passed
===> detect existing firmware structure...
detect ffs...
ffs offset/size: 02000000/02000000
firmware size: 32Mb
ffs size: 32Mb
detect sec ro...
detect custom parameters...
detect project-id...
project-id: MAUI.06A.W06.36.MP.V36
detect NAND info...
number of areas/bytes to read: 1:00010000
reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)...
bootloader version: SLT100_UKMERID_BOOTLOADER_V005_MT6228_MAUI_06A_W06 _36_MP_V36.bin
TCL-ID detection...
TCL-ID detection done
startup code area #1 detection...
startup code area #1 detection done
rom info ver: 04
sw version: SLT100_UKMERID_PCB04_GPRS_MT6228_S02.MAUI_06A_W06_ 36_MP_V36.BIN
project-id: MAUI.06A.W06.36.MP.V36, 00000000
code offset: 00000000
ffs offset/size [01]: 02000000/02000000
rom info structure: 2nd [standard] generation
TCL-ID is absent
===> done
startup code area #1 check...
startup code area #1 fixed
number of cores: 2
loading files...
number of areas: 2
done
write...
write bootloader...
write core...
Disconnect...
done
Finished, time used: 13 min 14 sec
YOR PHONE IS UNLOCK TNX TO INFINITY BOX
The Following User Says Thank You to faruk_gsm For This Useful Post:
Old 06-02-2010, 14:03   #10 (permalink)
faruk_gsm's Avatar
Member: 877161
Thanks Meter: 48
tnx .................................................. ....
HELP how to unlock iphone 3.1 laksh007 iPhone 2 / iPhone 3G / iPhone 3GS 7 03-31-2010 04:22
can i Unlock FLY SLT100 with Infinity ? .:Morpheus:. Infinity-Box 33 11-17-2008 10:30
unlocked fly slt100 not work on O2 mobilerepairs2 Infinity-Box 3 10-07-2008 21:30
how to unlock fly SLT100 ? the_frightener Infinity-Box 38 07-15-2008 17:09
Unlock Fly Slt100 Mansoor Infinity-Box 4 04-09-2008 15:53
Page generated in 0.36439 seconds with 8 queries
