11-18-2017, 21:56 | #16 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: Balkan Age: 50
Member: 1473716 Status: Offline Thanks Meter: 1,273 | Quote:
First you need to uninstal infinity emergency drivers and install qualcomm drivers ...for QPST with infinity emergency driver cannot find correct port for flashing.... After install QPST ..run QFIL and select next.... For Build Type select..Flat Build For Programmer path select...prog_emmc_firehose_8952_ddr.mbn Forload XML file,..select rawprogram0 For patch file ..select patch0 https://www.4shared.com/photo/kSEO85...sh_OK_OK2.html Thats All.... Last edited by gile@gile; 11-18-2017 at 22:01. | |
The Following User Says Thank You to gile@gile For This Useful Post: |
03-03-2018, 13:44 | #19 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Ukraine
Member: 74053 Status: Offline Thanks Meter: 75 | Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 010BB77D ID_BLOCK_L : 422B39909CD2F98B06EDFB1A37C06A71 ID_BLOCK_L : 7F4316C09E09A3E92C68B2CE0A90AA19 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8952 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000748000000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
06-09-2018, 20:07 | #20 (permalink) |
Freak Poster Join Date: May 2007 Location: Bolivia
Member: 514400 Status: Offline Sonork: 59170891380 Thanks Meter: 4 | hello sir i need you help , cat s60 not conet to infinity Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... BREAK : Device not found! HINT : Check cable, connection and drivers! Reconnect Power/Cable! and window driver install Qualcomm HS-USB QDLoader 9008 please helpme no conetc to cat |
06-09-2018, 20:31 | #21 (permalink) | |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | Quote:
06-09-2018, 21:31 | #22 (permalink) |
Member: 514400 Status: Offline Sonork: 59170891380 Thanks Meter: 4 | Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... ERROR : Fail to init protocol! HINT : Check cable, connection and drivers! Reconnect Power/Cable! i installCare Suite Emergency Connectivity but still giving error |
06-21-2018, 10:36 | #24 (permalink) | |
No Life Poster Join Date: May 2006 Location: zambia
Member: 272581 Status: Offline Thanks Meter: 118 | Quote:
06-21-2018, 11:33 | #25 (permalink) |
Member: 1473716 Status: Offline Thanks Meter: 1,273 | |
08-20-2018, 21:36 | #26 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | Cat S60 FRP Reset And Firmware Reading Done Remove FRP Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 028A20C2 ID_BLOCK_L : 8FF0F25D471F3E46435626D5F005D7B4 ID_BLOCK_L : F8C297471F8E226EA3E9314F8B0F2D96 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8952 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Remove FRP Reset Ok! Done! Elapsed: 00:00:45 Reconnect Power/Cable! Operation : Read Flash [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 652 [MSM8952] ID_BLOCK_S : 028A20C2 ID_BLOCK_L : 8FF0F25D471F3E46435626D5F005D7B4 ID_BLOCK_L : F8C297471F8E226EA3E9314F8B0F2D96 Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8952 , FLASH : eMMC , mVER : 1 MemInfo : 0x0003 / 0x0200 / 0x0000000747C00000 [ eMMC 32 GiB ] ExtInfo : 0x0001C000/00100000/00001000/00001000/00000200 Boot Ok! Brand : Cat ProdName : CatS60 ProdModel : S60 Device : CatS60 AndroidVer: 6.0.1 Manufact. : BullittGroupLimited QLMxCPU : MSM8952 DevInfo : MSM8952__BullittGroupLimited__Cat__ANDR_v6.0.1__S6 0__CatS60__CatS60 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : NON-HLOS.bin [Read Ok] : sbl1.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : hyp.mbn [Read Ok] : adspso.bin [Read Ok] : ddr.bin [Read Ok] : fs_gc.img [Read Ok] : persist.img [Read Ok] : misc.img [Read Ok] : mdtp.img [Read Ok] : cmnlib.mbn [Read Ok] : keymaster.mbn [Read Ok] : splash.img [Read Ok] : emmc_appsboot.mbn [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cache.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8952 / eMMC Firmware Size : 3262 MiB Done! Elapsed: 00:07:12 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to ..::GMSR::.. For This Useful Post: |
