09-03-2016, 13:43 | #1 (permalink) |
No Life Poster Join Date: Sep 2010
Member: 1388609 Status: Offline Sonork: atou Thanks Meter: 156 | how to unlock huawei LUA-L21 Chinese Miracle II [MTK module] v 1.55 Operation : Check / Read Info [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 203 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:06 Reconnect Power/Cable! Operation : Check / Read Info [ v1.55 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 203 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Boot Error! Operation Failed Elapsed: 00:00:26 Reconnect Power/Cable! |
The Following User Says Thank You to atou For This Useful Post: |
09-09-2016, 06:25 | #2 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Romania, The Bla Bla Country Age: 44
Member: 14279 Status: Offline Thanks Meter: 35 | same situation here: Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:07 Reconnect Power/Cable! |
The Following User Says Thank You to Alinus For This Useful Post: |
09-09-2016, 08:20 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Hold BOTH volume keys. After 2-3 try phone should be dead. Make need operation - ex - frp unlock. Do Init preloader. http://forum.gsmhosting.com/vbb/f296...l#post12032224 |
