01-29-2009, 01:14 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
how to unlock Huawei U1250 locked to virgin australia with qcom?? | dsakun899 | FuriousGold | 1 | 01-16-2010 09:07 |
how to remove Huawei t156 user cod plz help me Urgent | Master Software | FuriousGold | 4 | 01-09-2010 13:27 |
need to know how to unlock huawei c2205, if handset not ask for code, help!!!! | solution4mobile | Various CDMA/TDMA Cell Phones | 31 | 12-26-2009 08:34 |
Furious gold is not perfect to unlock huawei t156 | dawah telecom | FuriousGold | 1 | 01-16-2009 23:21 |
how to unlock HUAWEI U626 ???? | reo | Various | 1 | 06-03-2006 18:19 |
