11-11-2008, 19:15 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | How to unlock kp235 via pinfinder?? i dnt have cable KE500 And i need to unlock a KP235 using my pinfinder! i open pinfinder > select l18b > 2 Rx 3 Tx > which type to select plz?? infideon eg/sg?? mt62xx?? plz help |
11-11-2008, 19:26 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction with pictures: http://forum.gsmhosting.com/vbb/showthread.php?t=526956 |
11-11-2008, 19:50 | #3 (permalink) |
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | COM6 [VCP0] selected module v1.35 Device: LG-KP235 Checking data, wait... advanced flash detection active Action: unlock unlock method: standard Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 89881600010001:89881600000000 flash: Intel Intel/Sharp ext [def 0004x008000 00FFx020000] 32Mb id: 00005258 Boot Done Set baud... 115200 Set baud Done Check flash... current eeprom imei: 352127023896546 file saved: C:\Program Files\InfinityBox\LGA\eeprom_352127023896546_LG-KP235_20081111-234845.B1E.bin .... Check flash Done Check space... current eeprom imei: 352127023896546 .................................................. .............. finalization done Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... write: lock area-1 Write Done Finished, time used: 47 sec Remove/Install battery now ! THNX bro i 4got the steps UNLOCK DONE |
The Following User Says Thank You to khem For This Useful Post: |
11-11-2008, 19:57 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems and successfully done work. |
11-12-2008, 07:03 | #5 (permalink) |
Banned Join Date: Mar 2008 Location: pakistan city jhelum
Member: 720284 Status: Offline Thanks Meter: 13 | i am using infiniti box.but box can not conect with kg270.i am use same cable of kg270.i have not pin finder.i have only box plese any body help me how to conect to mobile kg270 and how to make a cable |
11-12-2008, 12:00 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
how to unlock KG225 Via Tornado | Fast Unlocker | UFS2 + UFS3-Tornadoflasher | 13 | 01-24-2007 13:51 |
how to unlock V3x via test point | datalife2000 | Smart-Clip | 1 | 03-02-2006 21:59 |
How to unlock T720 via flash/flex? | Wizard1 | Motorola P2k | 5 | 02-08-2006 14:46 |
Please help, how to unlock ST55 via IMEI !!??!! | jones | Phone Unlocking Codes & Maps | 9 | 10-08-2003 13:06 |
