09-06-2010, 08:42 | #1 (permalink) |
No Life Poster Join Date: May 2007
Member: 503911 Status: Offline Thanks Meter: 195 | How to unlock lg kg 110? Also tell me step by step procedure and which com port to select. I am new with infinity. |
09-06-2010, 10:22 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
09-06-2010, 10:25 | #3 (permalink) |
Member: 503911 Status: Offline Thanks Meter: 195 | tried all the things, cant unlock. i am very new with infinity. and just now installed the software. if you guide me only unlocking 1 phone rest i wll do. also tell me the settings of the software which option to check and which to uncheck? |
09-06-2010, 10:27 | #4 (permalink) | |
What "tried all things" you have tried exactly ? What COM port you have selected ? What do you mean "can not unlock" ? I can not understand what is the problem exactly. How can I help if you say just "not wark" and you do not explain what is the problem. | |
09-06-2010, 10:31 | #5 (permalink) |
Member: 503911 Status: Offline Thanks Meter: 195 | it is showing this only..........and when i hold power button the mobile set power on and nothing happen....... COM6 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: read eeprom Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! |
09-06-2010, 10:32 | #6 (permalink) |
Member: 503911 Status: Offline Thanks Meter: 195 | and when i press spunlock button it shows this COM6 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! and when i press power button the mobile switch on and nothing happen. |
09-06-2010, 10:34 | #7 (permalink) | |
Do you have RJ45 cable connected to phone ? | |
09-06-2010, 10:53 | #11 (permalink) |
Member: 503911 Status: Offline Thanks Meter: 195 | COM6 [VCP0] selected module v1.39 Device: LG-KG110 Checking data, wait... advanced flash detection enabled Action: unlock unlock method: standard Boot ... Phone should be Switched OFF ! Press and HOLD Power button now ! error: unexpected answer during boot procedure Boot Fail Finished, time used: 11 sec Remove/Install battery now ! |
09-06-2010, 11:01 | #15 (permalink) | |
If phone can not be detected by software, in 99% it's a cable problem, so you must double check cable wires and pins ! 2. be sure that you follow the instruction: Code: .... Phone should be Switched OFF ! Press and HOLD Power button now ! ... | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
