how to unlock lg kg 240 please hello i want to know how to unlock lg kg 240 please thanks for reply l br leroi |
Hello, Could you, please, tell me what is CPU name in this phone. Thanks ! |
i try to unlock Kg 340 selted Kg 320 and i have this information COM1 selected Device: LG KG320 Checking data, wait... Action: Unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200 flash: FEEA0000000000 flash: AMD/Fujitsu std [0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... current imei: 359102000437179 file saved: backup_eeprom_359102000437179_LG KG320_20070616-111813.B1E.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Err: wrong answer[39] Finished, time used: 17 sec Remove/Install battery now ! at end phone is already lock br leroi |
@leroi please, send me eeprom backup file: backup_eeprom_359102000437179_LG KG320_20070616-111813.B1E.bin also, pls, try to read flashh (like kg320) and send to me too: [email protected] Thanks ! |
i try to read flash of KG 240 selcted Kg 320 Testing COM1 at 115200... COM1 selected Device: LG KG320 Checking data, wait... Action: Read flash Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200 flash: FEEA0000000000 flash: AMD/Fujitsu std [0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Reading[part_1_of_1]...( reading flash file stop here) i try to unlock it as MG320 Testing COM1 at 115200... COM1 selected Device: LG MG320 Checking data, wait... Action: Unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200 flash: FEEA0000000000 flash: AMD/Fujitsu std [0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... current imei: 359102000437179 file saved: backup_eeprom_359102000437179_LG MG320_20070617-084804.B1E.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 16 sec Remove/Install battery now ! at end phone is already lock |
@leroi Mail received, thanks. Please, download and use http://www.infinity-box.com/download..._LgA_v1.15.rar Please, 1. read eeprom and send to me 2. try to make unlock I am waiting for your results. |
Read eeporom as LG K320 Release Power button ! flash: 01227E223C2200 flash: FEEA0000000000 flash: Amd PL256N D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Reading[eeprom-01]... file saved: backup_eeprom-01_LG KG320_20070618-105408.B1E.bin Reading[eeprom-02]... file saved: backup_eeprom-02_LG KG320_20070618-105412.B1E.bin Reading[eeprom-04]... file saved: backup_eeprom-04_LG KG320_20070618-105757.B1E.bin flash: 01227E223C2200 flash: FEEA0000000000 Err: wrong answer[39] Finished, time used: 239 sec Remove/Install battery now read as LG M320 Release Power button ! flash: 01227E223C2200 flash: FEEA0000000000 flash: Amd PL256N D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Reading[eeprom-01]... file saved: backup_eeprom-01_LG MG320_20070618-110203.B1E.bin Reading[eeprom-02]... file saved: backup_eeprom-02_LG MG320_20070618-110207.B1E.bin Reading[eeprom-04]... file saved: backup_eeprom-04_LG MG320_20070618-110553.B1E.bin flash: 01227E223C2200 flash: FEEA0000000000 Err: wrong answer[39] Finished, time used: 258 sec Remove/Install battery n unlock as Lg k320 Testing COM1 at 115200... COM1 selected Device: LG KG320 Checking data, wait... Action: Unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200 flash: FEEA0000000000 flash: Amd PL256N D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... current imei: 359102000437179 file saved: backup_eeprom_359102000437179_LG KG320_20070618-111421.B1E.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Err: wrong answer[39] Finished, time used: 19 sec Remove/Install battery now ! unlock as Mg320 Testing COM1 at 115200... COM1 selected Device: LG MG320 Checking data, wait... Action: Unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200 flash: FEEA0000000000 flash: Amd PL256N D 16Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... current imei: 359102000437179 file saved: backup_eeprom_359102000437179_LG MG320_20070618-111638.B1E.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Err: wrong answer[39] Finished, time used: 14 sec Remove/Install battery now ! |
LgA v1.15 (I gave link before) has ability to select KG240 model, not need to try to select other models. also make "advanced chip detection" box checked. So, please, make this: Please, download and use http://www.infinity-box.com/download..._LgA_v1.15.rar Please, 1. read eeprom and send to me 2. try to make unlock I am waiting for your results. |
ok let me try again |
COM1 selected Device: LG KG240 Checking data, wait... advanced flash detection active Action: Read Eeprom Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Reading[eeprom-01]... file saved: backup_eeprom-01_LG KG240_20000618-195336.B1E.bin Reading[eeprom-02]... file saved: backup_eeprom-02_LG KG240_20000618-195343.B1E.bin Reading[eeprom-04]... file saved: backup_eeprom-04_LG KG240_20000618-195727.B1E.bin flash: 01227E223C2200:FEEA0000000000 flash: 90009000900090:90009000000000 flash: 90009000900090:90009000000000 Finished, time used: 247 sec Remove/Install battery now ! UNLOCK LG KG240 COM1 selected Device: LG KG240 Checking data, wait... advanced flash detection active Action: Unlock Boot... Phone must be POWERED-OFF ! Press and HOLD Power button ! Connecting, wait... Release Power button ! flash: 01227E223C2200:FEEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb id: 0000527A Boot Done Set baud... 115200 Set baud Done Check flash... Check flash Done Check space... current imei: 359102000437179 file saved: backup_eeprom_359102000437179_LG KG240_20000618-195917.B1E.bin Check space Done Check parameters... Check parameters Done Erase... Erase Done Write... Write Done Finished, time used: 30 sec Remove/Install battery now ! PHONE IS UNLOCK THANKS BR LEROI |
