12-10-2018, 10:56 | #1 (permalink) |
Junior Member Join Date: Jan 2012 Location: Ukraine
Member: 1711811 Status: Offline Thanks Meter: 13 | How to Unlock Mi Account redmi note 5 pro Infinity-Box ? Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : FFA648A5 ID_BLOCK_S : 049BED48 ID_BLOCK_L : 362E36B4D338126B565C7EB0C339EDC3 ID_BLOCK_L : 69F2B9CCCFADECB0D3031A3EB8031F98 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported yet CPU! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Code: Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : FFA648A5 ID_BLOCK_S : 049BED48 ID_BLOCK_L : 362E36B4D338126B565C7EB0C339EDC3 ID_BLOCK_L : 69F2B9CCCFADECB0D3031A3EB8031F98 Pickup loader from firmware package Loader Sent! Initializing ... ERROR : FH Configuration failed! HINT : Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
12-12-2018, 15:00 | #8 (permalink) | |
Member: 1711811 Status: Offline Thanks Meter: 13 | Quote:
The way to enable the ADB - I did it, but in vain, these methods do not remove the password. The way to write through the MI flasher - unlock file - so too, it's tried, the file is not flashing, the flasher issues an authorization error. | |
The Following User Says Thank You to nikola_tesla For This Useful Post: |
12-18-2018, 10:32 | #12 (permalink) |
Member: 1711811 Status: Offline Thanks Meter: 13 | Support. Answer me. I count on you. My job is not moving in anticipation of the answer. If you are not going to add this phone model - I have to buy another software. |
12-18-2018, 12:12 | #13 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Ukraine,Kiev Age: 41
Member: 130762 Status: Offline Sonork: @martyn911 Thanks Meter: 127 | This model not support Buy other tool... Normal Mi account remove cost USD... |
The Following User Says Thank You to martyn911 For This Useful Post: |
