Old 12-10-2018, 10:56   #1 (permalink)
Member: 1711811
Thanks Meter: 13
Question How to Unlock Mi Account redmi note 5 pro Infinity-Box ?
Info to EDL mode to TP select:
Operation : Identify [ v1.16 ]
2. PRESS and HOLD BOTH VOLUME KEYS!
3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode!
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : FFA648A5
ID_BLOCK_S : 049BED48
ID_BLOCK_L : 362E36B4D338126B565C7EB0C339EDC3
ID_BLOCK_L : 69F2B9CCCFADECB0D3031A3EB8031F98
Use CM2 Internal Loader
ERROR : Prepare target failed! Unsupported yet CPU!
INFO : Send log and report.log to support! Include device info also!
Reconnect Power/Cable!
Ulock to EDL mode to TP select:
Operation : Reset Settings [ v1.16 ]
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
Pickup loader from firmware package
Loader Sent! Initializing ...
ERROR : FH Configuration failed!
HINT : Remove battery, cable. Check cable and connection. Repeat operation!
Old 12-10-2018, 11:37   #2 (permalink)
Member: 1711811
Thanks Meter: 13
attaching a screenshot
The Following User Says Thank You to nikola_tesla For This Useful Post:
Old 12-10-2018, 12:54   #3 (permalink)
kamal_singla's Avatar
Member: 2211790
Thanks Meter: 5,118
it's need VIP loader to boot handset
The Following User Says Thank You to kamal_singla For This Useful Post:
Old 12-10-2018, 14:33   #4 (permalink)
Member: 1711811
Thanks Meter: 13
And where can I get a VIP bootloader?
Old 12-11-2018, 10:48   #5 (permalink)
Member: 1711811
Thanks Meter: 13
support infiniti when there is a solution for this phone model?
*do you plan to support this model?
Old 12-12-2018, 10:37   #6 (permalink)
Member: 1711811
Thanks Meter: 13
Angry
somebody help me
Tell me if this software will support this model?
*Should I buy another software?
Old 12-12-2018, 10:39   #7 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
Originally Posted by nikola_tesla View Post
somebody help me
not possible with cm2 at this moment try another way or ask google mama.
The Following User Says Thank You to kothamamun For This Useful Post:
Old 12-12-2018, 15:00   #8 (permalink)
Member: 1711811
Thanks Meter: 13
Other ways are other box product.
The way to enable the ADB - I did it, but in vain, these methods do not remove the password.
The way to write through the MI flasher - unlock file - so too, it's tried, the file is not flashing, the flasher issues an authorization error.
Old 12-16-2018, 20:26   #9 (permalink)
Kolumb's Avatar
Member: 1558427
Thanks Meter: 630
I am also joining the author.
I am also interested in the decision on this phone model.
Old 12-17-2018, 01:02   #10 (permalink)
Member: 1372118
Thanks Meter: 139
this phone need ******* firehose
just use ******* firehose
Old 12-17-2018, 05:51   #11 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Thanks Meter: 1,214
cm2 not support it....
The Following User Says Thank You to >>Gsmmilon>> For This Useful Post:
Old 12-18-2018, 10:32   #12 (permalink)
Member: 1711811
Thanks Meter: 13
Support.
Answer me.
I count on you.
My job is not moving in anticipation of the answer.
If you are not going to add this phone model - I have to buy another software.
Old 12-18-2018, 12:12   #13 (permalink)
martyn911's Avatar
Member: 130762
Sonork: @martyn911
Thanks Meter: 127
Exclamation
This model not support
Buy other tool...
Normal Mi account remove cost USD...
The Following User Says Thank You to martyn911 For This Useful Post:
Page generated in 0.19595 seconds with 9 queries
