12-11-2006, 21:35 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hi, press #02# and tell me software version (like x.x.x) Also pls try to read flash from C122 (Run Moto01, select model C139) and send to [email protected] After I'll get flash backup I can check how to unlock this phone. |
12-11-2006, 22:38 | #4 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Thanks. Pls try to read flash from C122 (Run Moto01, select model C139) and send to [email protected] After I'll get flash backup I can check how to unlock this phone. |
12-11-2006, 23:23 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Try to unlock it like c115. If it will be no luck, flash phone with c115 flash files set version 1.x.x (main + LP + Flex). Waiting for your results. |
12-11-2006, 23:56 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | I don't think that it can be dead. What is battery voltage ? Post log after flashing here to check. what files you have used for flashing ? is it was any errors during flashing ? what software you used for flashing ? Last edited by InfinitySupport; 12-12-2006 at 00:08. |
02-08-2008, 09:11 | #14 (permalink) | |
No Life Poster Join Date: Aug 2007 Location: inside the pcb board
Member: 568876 Status: Offline Thanks Meter: 99 | Quote:
i have c122 moviestar...i cannot unlock.... i try to remove the n1 ball the do repair module and i used c115 file... then i flash it with c115 flash file...but no problem is the signal stock on searching...... i convert to 900 to 1800 band... i do jumper in the two filter then move down the 1 resistor but still searching????? c115 not work in c122???? | |
How to unlock Motorola P7689 | yui | Motorola Old Legacy (EMMI) | 3 | 05-31-2010 06:40 |
How to unlock Motorola Timeport 260? | odjebaus | Motorola P2k | 4 | 05-12-2002 16:21 |
how to unlock motorola d368 | ambot | Motorola Old Legacy (EMMI) | 0 | 05-21-2001 14:30 |
How to unlock Motorola phones | tomi_no | Motorola Old Legacy (EMMI) | 0 | 02-10-2000 15:52 |
