06-12-2012, 16:41 | #5 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Epinal Age: 71
Member: 56335 Status: Offline Thanks Meter: 26 | But, with calculator, I have this log : PID: 2ASFFR1 Modèle: OT-F344 SFR 3440 IMEI: 867242000XXX180 sec file: XF34CSA0 provider/sec-file initial check passed without code!!!! What do you mind???? |
06-12-2012, 20:53 | #7 (permalink) | |
MModule v4.31 uploaded in support area. Please, try to calc code for your phone with this version and post results here. | |
07-02-2012, 00:51 | #8 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Ouahigouya,Yatenga,BF Age: 64
Member: 486449 Status: Offline Thanks Meter: 10 | ==== [02/07/2012 00:28:04] ==== COM5 selected module v4.35 Device: _Autodetect MT6205-6239 NOR Checking data, wait... advanced flash detection enabled Action: read flash ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:A00F status: 03 Select another CPU type [6253] and try again ! Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 12 sec Remove/Install battery now ! Device: _Autodetect MT6250-6253 etc. ==== [02/07/2012 00:28:53] ==== COM5 selected module v4.35 Device: _Autodetect MT6250-6253 etc. Checking data, wait... Action: read flash NAND interface: BROM_DLL_v3.1108.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! bootcode current/expected: 0.0/3.2 CPU: 6253:8A04:8A00 status: 03 bbchip bl ver: FE NOR chip is not detected NAND chip is not detected Repeat operation, Press and HOLD Power button more long time ! internal RAM size: 00000000 external RAM [HW_RAM_UNKNOWN, CS0] size: 00000000 sec error code: AB error: can not boot device: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE error: last error: 1772:S_SECURITY_SLA_INVALID_AUTH_FILE Disconnect... done Finished, time used: 9 sec Remove/Install battery now ! ==== [02/07/2012 00:29:55] ==== COM5 selected module v4.35 Device: _Autodetect MT6250-6253 etc. Checking data, wait... advanced flash detection disabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6253:8A04:8A00]... CPU: MT6253 high speed boot On chip: 0000:0000:A00F status: 03 boot packet size: 0400 error: bootcode start error: A4 not authorized: 000000A4 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... error: no any expected answer : wrong answer after chip cfi request number of flash chip/regions detected: 00/01 flash chip is unknown or damaged. Fault reasons: 1. flash chip is damaged: replace or resolder/reball flash chip 2. hardware is damaged: check hardware, water inside etc. 3. unknown hardware: set "Advanced chip detection method" box [un-checked] and try again 4. wrong model selection, try 'NAND' selection Initialize Fail Finished, time used: 24 sec Remove/Install battery now ! |
SFR france iphone | .::allgsmkey::. | Main Sales Section | 0 | 05-13-2012 23:20 |
