02-04-2009, 19:39 | #1 (permalink) |
Freak Poster Join Date: Mar 2006
Member: 241452 Status: Offline Thanks Meter: 36 | a66 unlocked COM1 [Serial0] selected module v1.61 Device: ZTE-A61 Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... sw version: AIN-P108A17V1.0.0B01 15 48 16 ZAIN-P108A17B01-EnFr-NG01 g3dBV2.0 Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-static_20090204-072324.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-security_20090204-072326.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_eeprom-complete_20090204-072336.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\ZTE-A61_lock-area_20090204-072354.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 67 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to segun01 For This Useful Post: |
02-04-2009, 20:58 | #2 (permalink) | |
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. | |
problem with zte a66 unlocking | segun4u | FuriousGold | 24 | 12-21-2008 18:34 |
Zte a66 unlocked | GSM SKILS | SMTi | 11 | 11-09-2008 17:17 |
zte A66 unlock | abote didier | ZTE | 4 | 10-14-2008 13:25 |
ZTE A66 unlock issue | leroi | Infinity-Box | 1 | 10-05-2008 19:26 |
Zte A66 unlock | abote didier | ZTE | 0 | 10-02-2008 13:58 |
